Question about Cameras
I haven't done anything like drop it but my lens is clean and it is no problem with the screen, as I can still take images and they turn out fine. I cannot take video though. As you can see from the v
    Sergeant:
    Champion:
  • 370 Answers
Its a CCD Problem ......get it rebonded if the local repair shop does it ...... or get it replaced.....
Posted on Nov 01, 2012
t00nz
  • 4738 Answers
SOURCE: dropped Nikon Coolpix L3
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Dec 23, 2007
zohail
  • 1223 Answers
SOURCE: images fine inside but outside natural light images overexposed
CCD is going for Failure !
it starts like this first indoor ok and outdoor over exposed then
indoor pics also when u see them closely turns pink or green in shades then horizontal vert lines appear then completely blank
just check with casio if they have issued service advisory for the CCD failure problem as all others have issued they will do it free of charge
see link
http://www.imaging-resource.com/badccds.html
Posted on Apr 11, 2009
dragos_adria
  • 45 Answers
SOURCE: My fuji finepix E510 records images with
take a close look to the lens, and if is clean, you have two possible problems 1. the CCD part is almost dead 2. the CCD connector is not in the right position, so you will have to open the camera and ensure that connector is properly set and the lock is on.
Posted on Feb 28, 2010
  • 1040 Answers
SOURCE: Blurry images (after a lens error)
There is a mechanical displacement in your camera. Definitely, it is not a software problem. Actually Digi Cams are very delicate, especially small ones.... So get it serviced from a authorised service station. They will fix the problem....
Pleas rate the answer iof you find it useful.
Posted on Apr 27, 2010
Testimonial: "Thankyou for that :)"
  • 34 Answers
SOURCE: The screen stays black.
Look at the front at the lens. Turn the camera to picture mode. Point the camera at a light above you. Take a few pictures and watch the lens.
You should be able to tell if is functioning correctly or if its broken. It sounds like it has been dropped.
Your Friend,
Sleek Mouse
Posted on Mar 15, 2011
The screen will not show the image. it looks as if the screen is cracked, but there is no crack on the screen. also the zoom will not go in or out. the camera turns on, you can hear it and the lights on...
firts resolve the lens issue
1.- Clean the lens surface with a soft cloth (clean the cilinder body of lens)
2.- Turn OFF the camera.
3.- Gently Push the lens
4.- Gently PULL the lens while you turn ON the camera
Check if the lens go in and out. If the lens don`t move try again step 2 to 4
If the lens move, and the Screen continue NOT image (screen is white) you need replace the lens sensor
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 22, 2011 | Kodak EasyShare Z650 Digital Camera
I can take oictures But will not transfer to PC say no image images are on the cameras also on screen is F3 at the bottom never seen that before can you explain
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Black spot on pictures - cleaned lenses and inside
The spots can be in the inside of the lens settings to the CCD/imager.
If the cleaning of the lens is done well it can be a speck of dust logged in to the screen and having it on the image.
A careful cleaning in a dust proof set up is required.
Sep 25, 2010 | Nikon D50 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Kodak m893IS is not turning on....the camera was dropped by accident but it wasn't dropped from high it was only like 2 feet...after it was dropped it worked fine for the next 5 minutes but then it turned...
You may have bent the camera's lens housing, which will require professional repair, but the problem you describe is frequently due to corroded battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, clean the contacts at both ends of the batteries, and reinsert them in the camera. This cleaning cures the problem about 90% of the time, and I hope it works for you.
Sep 03, 2009 | Kodak Easyshare M893 Digital Camera
Camera powers up fine. Black screen when looking
some cameras have different languages
find the one that related to view images and the camea must be on and othe funtions are automatically diabled at that moment in time.
Jul 31, 2009 | Canon PowerShot A630 Digital Camera
My Sony W-80 series camera turns on fine, the screen works, but its black. Its like the lens isnt open, but it is! and when i take a photo its recorded black. I had it in my bag so may have been jolted...
So the lens opens,
But screen stays dark - can you see any shadow images or is it totally dark?
Have you checked that images are in the card.
Any way there is not repair option just replace it.
Aug 26, 2008 | Sony Cameras
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
