Question about NEC MultiSync FE991SB 19" CRT Monitor
There is black line down left side of monitor 1/2'' wide
I recently moved it and probably accidentally pressed the settings buttons on the front and now need a users manual
I found the users manual
Posted on Jan 04, 2009
...hi, i've got a 2" wide black vertical area on
That reads like an alignment problem on the monitor, rather than a computer setting.. If you have a flat-panel monitor, usually on the front, lower right or along the right side, you can press a Menu or Settings button, press + or - to the Horizontal setting, press the Select button, then press the + or - button to move the display to the right. Press the Select or Menu button again to set the new location.
The actual button designations could be different.. best if you look at the manual on the monitor.
If graphics card will let you oversize the display, it might also have a Pan option that would let you slide the display back to the right. In that case, look in the Notification area (lower right) of the screen for a graphics card icon that will let you Pan right.
Oct 30, 2013 | Computers & Internet
How to change orientation of monitor
I'm a little unclear of what you are asking.
1) Screen has turned on monitor?
Press the CTRL key, and ALT key down at the same time.
Now tap on the Left Side Arrow key, until the screen is oriented correctly again.
2) Screen on monitor has shifted left, right, top, or bottom?
Use the controls on the monitor to set it correctly again.
3) Using dual monitors?
Right-click on an empty space on your desktop screen.
Left-click on Properties at the bottom of the list.
Left-click on Settings.
The monitor 1 icon is supposed to be your Primary monitor.
The monitor 2 icon is the Secondary monitor.
Ordinarily the Primary monitor is on the LEFT side, and the Secondary monitor is on the RIGHT side.
Just as shown in the Settings window.
If you wish to move a monitor to the other side, go to the monitor icon you wish to move.
Put your mouse cursor on the monitor icon you wish to move.
Left-click, and hold the left mouse button down.
Now drag the monitor icon you wish to move, to the other side.
Not doing it for you?
Then post in a Comment with more exacting information, as what it is that you wish to do.
Regards,
joecoolvette
Aug 02, 2012 | E-Machines eMachines Desktop PC
Screen has black line on leftside and picture has moved over were the right side has moved to the left side uncentered
hi! i had this same problem, and JUST fixed it! its really simple.... on my monitor, i have a bunch of buttons and whatnot. its a 'viewsonic' which really is quite out of date.... but on the menu, there was a setting that was 'auto image adjust' i pressed it, and now everything is fine! and the black bars went away! i hope this helped..
May 23, 2010 | Akai PDP4298 Television
Black line down right side of screen
turn off laptop.
press and hold on the D then press Power button.
during the LCD BIST test check if the black line down right side of the screen is visible. if yes LCD needs to be replaced. if not connect your laptop to an external monitor check if the black line display appears to the ext monitor, if yes uninstall / reinstall video driver if fails replace video card or if it is built in replace motherboard.
if no ext monitor available then run PSA (press and hold Fn key then press Power button)
check if the black line is visible. Check also in BIOS is black line is visible, if yes then uninstall reinstall first the video driver if fails replace LCD.
Oct 11, 2009 | Dell Inspiron 9200 Notebook
Hi, I am Barbara Acer X193W LCD Monitor. I
If the screen is side ways, it is caused by unintentional pressing Ctrl-Alt plus a left or right arrow.
Restore by pressing Ctrl-Alt plus up arrow
If the screen is upside down
Caused by unintentional pressing Ctrl-Alt plus down arrow.
Aug 23, 2009 | Acer X193W BD 19" Wide 1440x900 LCD...
Two inch wide black lines down center of paper
It probably the cleaning blade on the drum unit ( deformed rubber blade )
Mar 24, 2009 | Sharp Office Equipment & Supplies
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Opening the dell 1707FP monitor
To open the case, do the following:
1. Remove the base from the back of the monitor by pressing the large black button on the back.
2. Remove the 4 large black screws located under the plate you removed in step 1.
3. Along the left side, towards the top of the monitor, locate the seam that divides the front from the back of the monitor. This is located along the left side and is about 1/16" back from the front of the monitor.
4. Using a flat blade screwdriver with approx a 1/4" wide blade, work the screwdriver into the left side seam, almost to the top of the seam. Your screwdriver should be going into the crack between two pieces of black plastic.
5. Gently turn the screwdriver left and right until you feel the front separate from the back.
6. Once you have a "hole" to start working from, gently pry the rear cover away from the front bezel. Make sure that the bottom right corner (closest to the power and adjustment buttons) is the last part of the front that you attempt to pry apart. Be extremely careful in this area, as the buttons are part of a small circuit board attached to the front bezel. While it seems like front bezel is the piece to remove, actually you want to remove the back case first. Pulling the front bezel too far away from the LCD screen itself can damage the flex circuit. Once you remove the back cover, you should be able to see the red and white flex circuit that goes to the front panel circuit board.
7. Gently fold the bezel away from the LCD screen, keeping the bottom edge of the bezel close to the screen. Again, use caution not to damage the flex.
8. Once this is done you should be able to see a green circuit board with 5 very small phillips head screws. Remove the screws and find a safe place for them. Once this board is removed you should be able to see the cracked button. In my case I just removed the pieces of the button and powered on the monitor using a small q-tip. Once reassembled, the actual button is inside the hole, but off to the left. The two contacts that you see directly behind where the button used to be are LEDs to indicate the power is on.
NOTE: In place of a q-tip, you can use any small, non-metallic, not sharp object. A pointy pencil eraser might work well too.
Reassembly is the reverse of disassembly. Hope this helps!
Jun 25, 2008 | Computers & Internet
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
NEC MultiSync FE991SB 19" CRT Monitor Logo
418 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
