No clock or power to panel after plugging in there was a electric short
The stove and ovens were working ok until I got it to a friends house and then when I plugged it in, there was a power circuit short, now it does not seem to work at all. Is the control panel fried?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Yes, sounds like you have a fried board. What is the model number?
Posted on Nov 01, 2012
SOURCE: No power to machine - there is power to the plug
and washer have fues where
Posted on Oct 11, 2008
aborcass
  • 2651 Answers
SOURCE: Admiral Electric Oven Control Panel Issue
that is a part number to the clock assy, assuming you have 110v to L1 on back of the clock and no display , that s a preyty safe bet youll need to replace that clock assy
Posted on Nov 09, 2008
localwonder
  • 6784 Answers
SOURCE: stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Posted on Apr 02, 2009
I had the same thing happen. I took the top off and realized that the power cord from the factory went out the back.....back in an opening.....across the back but on the inside and out another opening. The part crossing the back on the inside was near the motor and belt and was cut through the hot wire and ground. Someone has to be an idiot to run the wire in the design on the inside.
Posted on May 31, 2009
barkencoa
  • 3463 Answers
SOURCE: hoover vision hd washing machine was working then
Could be faulty door interlock, as nothing will work until this activated..
On the other hand, could well be power module or display module that is faulty.
The only thing thing you can do at the moment is to remove the top cover, and see if there is anything obvious looking in at the top
Hope this helps.
Posted on Feb 01, 2010
Frigidaire stove
Power outage could have shorted out the control panel. Call the power company and put in a claim with your insurance company. Tis happened to me & I was able to reset the oven, even with a glowing bright & dim panel. Thought everything was ok but the upper oven doesn't stay on & the oven probe doesn't work, but it's too late for me to file a claim.
Sep 05, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Ge oven clock and oven dont work
Hi!1 your control board is shorted need a new control clock board..Just remove the screws to the top back panel and you will see the the main board easy to fix..Just buy main clock board..Good luck..
Jan 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
