Question about Fisher and Paykel Washing Machines
I have a fisher and paykel smart drive excellence and the water fills intermittantly then stops all of a sudden. it will drain and the washer is not moving freely. spin light starts beeping and blinking
    Top Expert:
  • Fisher and P... Master
  • 9,472 Answers
What is the model number of your machine?
Posted on Nov 02, 2012
hattonhall
  • 349 Answers
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Posted on Oct 19, 2009
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Posted on Jan 11, 2008
  • 3 Answers
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Posted on Feb 20, 2010
SOURCE: starts and stops
Fisher & Paykel GW708\r\nWashing machine stops and starts filling then starts beeping and the long wash light 1 and the 7th light are lit up. If I turn off the power I can restart and eventually fill machine but it will error again when it needs to fill up again.
Please help.
Posted on Jul 30, 2010
Our Fisher and Paykel excellence 5.5 smart drive 9, washes fine but when it comes on rinse cycle it wont drain the water and makes a humming sound.
Check your pump with a multimeter for correct reading
230V AC Pump 50Hz 33Ohms +/- 8% @ 20oC
110V AC Pump 60Hz 7Ohms +/- 8% @ 20oC
Also check for blockages that may stop pump from turning.
Disconnect from power & Bail out all the water you can before removing pump.
Jul 07, 2012 | Fisher and Paykel Washing Machines
My fisher paykel eco-smart washer is filling up with water at the same time it is pumping the water out the drain.
My washer is filling up..but not very high and at the same time it is pumping out water into the sink. Will not spin or rinse
Jan 01, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
Fisher and Paykel Smart Drive 015 won't fill with water. Have cleared hoses, filters, and replaced water valve and soleniod.....
if you have replaced water valves and still not working you need to check if power is supplied to valves also does the machine do any other functions like draining or spinning if you advance it if not possible fault is lid switch if the machine stop starts continually possibly out of balance switch faulty if none of the above control board may be faulty hope this helps
Nov 04, 2009 | Fisher and Paykel GWL11 Top Load Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Dec 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
400 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
