Television is on standby-red light is flickering but the set will not turn on
Set will not respond to signal from remote control to turn on-the power button just keeps flickering-the only commamd it responds to is to turn off
  • 127 Answers
The power supply needs to be repaired or replace the Module.
Posted on Nov 01, 2012
Cybertech
  • 149 Answers
SOURCE: Magnavox 15MF237 LCD - stuck in standby
just one idea.. some set you may program to stay on in case you use cable box and when you turn on the box tv turn on same time but may be defective tv there is relay,transistor and the micro that may be bad so check your settings again ... Good luck
Posted on Apr 10, 2008
SOURCE: channel buttons (up/down arrows)
Do an autosearch in the setup menu and that should program those buttons. Weird I know, but it worked for ours!
Posted on Jun 22, 2008
SOURCE: won't respond to volume or channel changes red light blinks 20x's when turned off.
It's definitely a firmware problem. I called Panasonic and they were very polite about the entire situation and sent me a SD card with the firmware update. If you don't have time and you're tired of listening to tv at the same volume there is a way to do a hard reset.
I figured that unplugging the unit would do this, but there is one other step that you have to do to ensure that this works.
Generally the power button on the tv is always in the "on" position, this is what allows the remote to work. In order to do a hard reset the on/off button must be in the off position. Make sure that is off, then unplug the unit, let it sit there for a minute or two and plug it back in. If the tv comes back on as soon as you plug it back into the wall/powerstrip then the button was not in the off position.
This isn't the best fix, you'll still need to get the firmware update but it will at least give you the ability to use your tv normally....well until it decides to randomly lock up on you again and you have to do this all over.
Posted on Oct 02, 2008
dsacco86
  • 1077 Answers
SOURCE: Red light turns on, But not television
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. It maybe something simple like a blown fuse inside the TV. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searchingon the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 20, 2009
budmrtn
  • 11361 Answers
SOURCE: RCA L26WD12 26IN, LCD TV will not turn on, the red
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 12, 2010
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
My Olevia 27in. LCD Television does not turn on
Well, at least the standby 5vdc circuit is still working but the problem can be in the controller board is not sending the signal to turn on the main power supply sections, or the power supply itself is bad. Look at the power supply first for burnt parts, bad capacitors.
Nov 10, 2009 | Olevia LT27HVX 27 in. LCD Television
Remote control does not respond even with new batteries in, a red light at top of device blinks but the set does not respond
easy way to check if remote control is emitting IR signal is to aim it directly at digital camera lens(cellphone cameras work great for this) while pressing any button on the remote you should see bright light flickering on camera display, if there is no light remote is bad otherwise receiving device in the set is not working
Sep 02, 2009 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote control set up code
Try searching for the code
To search for your television code:
1. Switch your television on (not in standby).
2. Press and hold down MAGIC until the ONE FOR ALL
1 red light blinks twice (the red light will blink once
then twice).
3. Press 9 9 1. The red light will blink twice.
4. Next, press POWER.
5. Aim the ONE FOR ALL 1 at your Television. Now press
CH+ over and over, until your Television turns off
(every time you press the CH+ key the ONE FOR ALL 1
will send out a POWER signal from the next code
contained in the memory). You may have to press
this key many times (up to 150 times) so please
be patient.
If you skip past a code, you can go to the previous
code(s) by pressing the CH- key. Remember to keep
pointing the ONE FOR ALL 1 at your Television while
pressing this key.
6. As soon as your television
Aug 21, 2008 | Televison & Video
Programing universal remote
Turn the TV ON. You can use the code search option by pressing Code until the LED flashes. Press the Power button until the TV turns off. Then press Enter.
Jan 20, 2008 | Televison & Video
Sony KV-32S22 32" TV Problem
Intermittent dead with red standby light on, but won't switch back on, comes back on it's own, won't respond to remote or local controls
Low 5v standby supply due to diode D869 faulty, check by replacement
Nov 23, 2007 | Sony KV-32S22 32" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
