Question about Dryers
Stop button doesn't work on Amana NED7200TW Electric Dryer.
  • Mike Carroll Nov 02, 2012
    I already did that. It is not the door switch.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Posted on Nov 01, 2012
Illeagle
  • 525 Answers
SOURCE: Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
Posted on May 26, 2008
EllaWatson25
  • 725 Answers
SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Posted on Nov 17, 2009
  • 1214 Answers
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Posted on Dec 11, 2009
  • 31 Answers
SOURCE: How to Open an Amana DLE330RAW Electric Dryer
pull the nobs remove the back panel and you will see more screws and then gently pry it u(unplugged ofcours) and it shoud pop off.screws are in the side too I think
Posted on Dec 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I am in need of
Hi jenflint78...
Try some of these solutions first...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 27, 2011
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
My amana dryer model ned7200tw runs good but no heat
check element, termo fuse (top side of element casing) and electric box as it can run with one side (117 Volts) good and one bad..
Jan 05, 2015 | Amana NED7200TW Electric Dryer
I have a Amana Dryer NED7200TW. At the end of any drying cycle the dryer shuts off and then turns on again continuously untill i stop it. It also shows a C and a backward C in the display. Any thoughts?
You might need a new display board (electronic timer ). Seems like the timer will not send the message for the dryer to stop when the cloths are dry
Jul 25, 2012 | Amana NED7200TW Electric Dryer
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
I have a Amana 7200 Gas Dryer, it gets warm but not hot enough to dry one cycle. It now takes about three, what could be wrong or faulty?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Amana NED7200TW Electric Dryer
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
Dryer lights up but drum doesn't turn. Can manually move drum but difficult.
I would like by your description you have a obstruction in the blower wheel preventing the motor from turning freely. I would seek to find an item of clothes in the blower wheel preventing the motor from turning.
Thats where I would look, I hope this helps
Aug 08, 2011 | Amana NED7200TW Electric Dryer
My Amana NED7200TW runs but will not heat up. I don't get any error codes. Help.
heatman101;
May 10, 2011 | Amana NED7200TW Electric Dryer
Amana dryer NED7200TW quit heating, it appears everything else is working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Amana NED7200TW Electric Dryer
Can't find new heater for NED7200TW Amana dryer.
Here is the part...
http://www.partselect.com/MultiModels.aspx?ModelNum=ned7200tw&searchTerm=&RefineSearch=0&Page=2
Hereis a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 22, 2010 | Amana NED7200TW Electric Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
