Question about Amana Dryers
Off button doesn't work.
The off button only works intermittantly.
  • Mike Carroll Nov 02, 2012
    I am not sure what you are trying to do.
    Top Expert:
  • Amana Master
  • 9,472 Answers
See my other post.
Posted on Nov 01, 2012
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Leica Disto D3a shows ERROR 220
I had this exactl problem and resolved it by replacing the batteries
Feb 19, 2013 | Leica Digital DISTO D3a 100M Laser...
Lmd 9050 menu button doesn't work
you will need to remove the back cover to access the button panel board. then check for a loose connector, if ok check for an stuck up switch in the button panel.
Nov 15, 2012 | Sony LMD-9050 Monitor
My temperature gauge,Tachometer,Speedo,Fuel Tank on my 2003 Opel Astra 1.6 16v Elegance doesn't work intermittantly
connection on the back of the dash needs cleaning if you push on the dash and it all works then this is the fault. sometimes hitting it works just fine for awhile but not to hard.
Sep 13, 2012 | Opel Astra Cars & Trucks
My power windows only work from the driver side
the driver side door usually holds the master switch panel. which has the window lock button/switch. if the button doesn't activate/deactive, the whole switch panel has to be change out.
Aug 02, 2012 | Dodge Dakota Cars & Trucks
My 1996 Olds LSS doesn't idle properly,idling surges sometimes,the temp. gauge doesn't work and sometimes the heater doesn't work.It may stall while driving.If I get in and the power seats...
Your first problem is to find out why the intermittent no-power problem. Honestly, that sounds like a loose conmnection somewhere. check all your grounds for clean and tight conditions Also, battery connections and alternator connections. Double check your power distribution center for any loose wires or poor connections. Once you solve that problem, then you can diagnose the other problems with poor idle and temp. gauge.
Oct 17, 2011 | 1996 Oldsmobile LSS
2007 Eos bought end of May w/ 109K miles. Cruise Control switch doesn't work. If in ON position when cranked AND I can get up to a cruise-worthy speed, it'll work. But, then, sometimes it'll...
The cruise control issue is a common problem. The switch that is behind the steering wheel tends to wear out and the whole stalk will have to be replaced. I had the same problem with mine. It would work intermittently and over time it stopped working all together. I replaced the stalk and it was fixed
Aug 15, 2011 | Computer, Chip, Cruise Control for...
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
