Question about Compaq Computers & Internet
What does it mean when your laptop's power lights flash ? Including the power button?
I did realise that the power lead was out but it does not usually flash like this when the power lead is out?
    President:
  • 739 Answers
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Posted on Nov 01, 2012
StuartB
  • 807 Answers
SOURCE: lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Posted on Feb 01, 2012
anandsharad
  • 137 Answers
SOURCE: Laptop will not boot. The power light flashes
CLICK HERE
the codes which you see are universal for all the dell laptops. find the appropriate. this will solve your purpose and guide you how to go furthur.
Posted on Sep 26, 2009
djbr1ck
  • 158 Answers
SOURCE: E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
Posted on May 12, 2011
  • 3278 Answers
SOURCE: My laptop Vostro 1320 wont
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
It's also possible that your motherboard is problematic.
Hope this helps.
Posted on Sep 24, 2011
  • 15 Answers
SOURCE: toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Posted on Jun 18, 2012
What means when the power light keep turning on and off
Hi Essa
Have a look in your manufacturer's handbook/manual.
It's more than likely the lights flash but not charging your laptop because it has sensed that there is a charging lead plugged in but the laptop is not receiving current. This could mean one of two things:
1. The charging socket is faulty and needs to be replaced
2. The Charging lead is faulty (wrong laptop lead or non genuine)
If you have a multimeter and you are proficient in it's use you can check the voltage coming out of the charging lead to see if it's working or not.
Regards
Andrew
May 18, 2014 | Computers & Internet
Flashing battery and power light
Hi Micheal,
your question is a bit vague?
does that mean your laptop does not turn on at all?.
you could try putting the power suypply into the power outlet onthe laptop if the battery on the laptop is faulty it should boot up as normal.
if the battery is faulty , you will have to get a new one evewntually you can get one on ebay for low cost, i think there is a quick fix.
turn of the laptop
take the power lead out of the jack.
take the battery out of the bottom.
hold the laptop upside down and hold the power button in for 2 mins after this recconect the battery and power lead and try turninig on if it worked the battery shiould start charging and should last for at least 10 mins.
Hope this helps.
Dec 29, 2012 | Computers & Internet
Not booting but power button flash
Since you didn't tell us what kind of laptop you have, or what system you're running, we can only guess.
If the power button is flashing, usually it means the laptop is asleep or in hibernation mode. Check your laptop's documentation on how to wake it up, or bring it out of hibernation. On some models, you can press and hold the power button to shut it down then power it on again.
Hope this helps. Please rate my response
Randy
Aug 31, 2012 | Computers & Internet
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
Compac d-530 won't start red light under power button flashing
Take out the battery and only hook up the AC Adapter. Try turning on your laptop and if you still only get a flashing power button then try another AC Adapter. If the same thing happens then that means the motherboard is bad and would need to be replaced.
Feb 05, 2012 | Computers & Internet
May 12, 2011 | Computers & Internet
The machine won't power up. The green light on the PS flashes. What does this mean? If I disconnect the large plug from the mother board the green light will come on steady. Plugging it into the mother...
Can you tell if the flashing is a pattern. count the flashes ( long and short) in a cycle. This will provide an error code to hopefully discover the problem.
You may also try removing and reseating the RAM and Video card, blowing out the connectors with compressed air before reseating.. Also look closely at the components on MB for any signs of swelling, leaking, burning etc. I suspect the MB.
Nov 11, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Jul 06, 2010 | Dell Dimension E310 PC Desktop
Aspire 1640, when i press power button, battery light flashes a few times and then nothing
that means it's not powering up... Take out the battery...hold power button for about 60secs and start the laptop with the adapter...if laptop powers up this will clear one thing...it's the battery if not then might be your adapter...check the voltage...try plugging in another adapter. Check the battery if it's working with any other laptop. Try lightening the laptop remove any external attachments[printers,scanners,pen drives etc.] All this you can try on your own and other than this leads to internal problems.Call any authorized personal from the company.
Aug 02, 2009 | Acer Aspire 1640Z Notebook
Computers & Internet Logo
400 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
