Question about Compaq Computers & Internet
Lap top screen only shows background picture
Will switch on and off but only the background picture comes up and the cursor its impossible to do anything no lettering etc on screen at all.I've tried all the keyboard keys and nothing happens .
  • Compaq Master
  • 7,627 Answers
Does the mouse work? I would Cold-stat the machine: 1) remove AC plug from outlet, 2) remove battery, 3) hold down on/off button for 10 seconds, 4) replace battery, 5) plug into wall outlet 6) push on/off button.let me know if there is any change, if not you can try another procedure.
Posted on Nov 01, 2012
BulletSponge
  • 38 Answers
SOURCE: I am unable to type
You can either contact the manufacturer of you notebook and request a replacement keyboard, or you can use a USB keyboard instead.
Posted on Dec 18, 2008
pcsyke
  • 152 Answers
SOURCE: Brand new Toshiba Satellite L750
Hello there,
Drivers and Manual Link
Try pressing, Function key + F9..
F1= Lock Computer Mode F2= Change Power Settings F3= Change to Sleep Mode F4= Change to Hibernation F5= Switch Active Display F6= - Brightness F7= + Brightness F8= Enable/ Disable Wifi F9= Enable/ Disable Mouse cursor
About the keyboard lock? I have no idea, because most laptops have cursor lock only. Correct me if I'm wrong. Hopefully this helps.. Thank you for posting..
Posted on Jul 12, 2011
  • 19 Answers
SOURCE: I have an asus g74sx when I turn it on it only gets past the asus title screen then to a blank screen with a cursor flashing on the top left corner. I've tried hitting f9 but all it does is restar
Try hitting f12 or f10 at bootup this should give you bootup repair options
Posted on Feb 19, 2012
  • 6771 Answers
SOURCE: Presario cq62 keyboard not working
Hook a external keyboard to make sure it is working, if yes! the laptop keyboard will need to be replaced.
Posted on Mar 17, 2012
SOURCE: asus netbook cursor stuck
Make sure there is not a lock on the top middle of the touchpad that you can press to toggle the lock/unlock. if so, press it. Otherwise I would try booting up in safe mode and see if the cursor locks.
Posted on Mar 30, 2012
How do I put pictures on my lap top
u may need to install drivers
http://414dd714.picbucks.com
Dec 08, 2013 | Kyocera Cell Phones
Aspire 5349 Windows 7
harry not a joke but this happen many a times.
dont know d reasons. but try with win xp.
Format c drive properly.
then if you want upgrade with win7..
Dec 17, 2012 | Acer Computers & Internet
Lap top screen is sideways how do I turn it upright
right click on your background and it will show screen resolution click it and a window will pop up click on landscape flipped and change it to landscape.
Aug 05, 2012 | Dell Inspiron 9300 Notebook
IN n150 mini lap top i am not able to change the background
Hi
we dont know what operating system you are running
so here are a few quides which may help
if you have a picture that you want as desktop background
go to the picture and click on it
then right click it and go down to and press
set as desktop background that should then put that picture there for you
or go to start
control panel
appearance/personalization
and either choose
change the theme
change desk top background
different operating systems deals with this in slightly different ways
good luck
Feb 23, 2011 | Samsung N150 Notebook
I have the Dell 1525. The screen is black with only the cursor appearing. Please advise
Check to see if you have the machine switched out to a stand alone monitor. This is a feature on many lap tops that lets you re-direct the signal out to a larger monitor, or if your monitor fails you can display the computer info on another screen. This feature is engaged by holding down the Fn key and tapping teither the F4, or F6 key on many lap tops. This feature can be toggled by both displaying at the same time or switched to the stand alone or the Lap top.
The other cause is that the machine has malfunctioned usually because of the CPU failure and there is nothing to boot the machine up.
Dec 30, 2010 | Dell Inspiron 1525 Notebook
Screen savers
Go to Control Panel choose Display Properties go to Desktop tab there is a selection from Position: center, stretch, tile choose the stretch then apply and ok, your picture will displayed in full screen in your desktop
Nov 09, 2009 | Computers & Internet
Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Computers & Internet Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
