My Frigidaire washer is leaking out the bottom by the drive shaft
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
5 Suggested Answers
  • 378 Answers
SOURCE: I have Frigidaire front loading. During the spin
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Apr 03, 2009
SOURCE: Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Posted on Aug 18, 2009
  • 97 Answers
SOURCE: water is leaking from top loading frigidaire crown washer
go on line find model number on the back of washer
you should be able to fine seal kit and yes a new seal kit well do the job you well have to remove the drum unclamp hoses and remove you may want to have repairman come do this.
Posted on Nov 25, 2009
  • 1531 Answers
SOURCE: Frigidaire GLWS1233A Top Load Washer
there is a chance that the tub seal is broken. in orfer to check it you need to remove the front panel by taking the two screws out of the bottom the push the two clips in that are located about an inch in from either side of the washer the lid will pop up and then you can remove the front panel.
then start the washer again and look to see where the water is coming from
Posted on Sep 17, 2010
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
We have a Frigidaire top loading, 8 cycle, heavy duty, super capacity 2 speed washer and it does not have a model number on the inside lid. The washer is leaking at the point where the drive shaft connects...
the part needed to be replaced is the main tub seal and it is not hard to do. remove the agitator the you will see a collars that has two bolts on the side of it this keeps the inner tub attached to the drive shaft you may also have one that is broken.
lift the washer lid. then remove the tub ring that is on top of the outer tub once this is removed you can remove the inner tub.there will be a brass ring with a black rubber piece in the center of it this need to come off in order to get the tub seal out. it maybe a little difficult toe remove but it just pulls up. you may have to use some liquid soap on the drive shaft to make things easier to slide up and off
Aug 28, 2010 | Frigidaire CWS3600AS Top Load Washer
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Feb 23, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Water is leaking from top loading frigidaire crown washer
Nov 25, 2009 | Washing Machines
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Leaking washer
remove 2 screws bottom front panel pull panel down should drop and can be pulled out of way ckd area around pump also around center shaft where it goes through bottom of tub lest likely hole in tub make sure small hose back left is attached to small connector on side of tub
Jul 10, 2008 | Washing Machines
Washer leaking from bottom of tub
If you have the tub out the seal can be removed by taking the brass ring off the shaft, its on top of the seal, then grab the seal with a pliers or pry it out with a screwdriver etc. The new seal will cost about $40-$50. when you put the new seal in put the rubber part on first, careful to not tear it on the slot cut in the shaft to mount the basket. Next put the old brass ring on top of the new one, use this to push the new ring on, this will help get it over the notch for mounting the basket. When the new ring is ontop of the seal remove the old ring, reassemble, check for leaks.
Jun 08, 2008 | Frigidaire FWS833A Top Load Washer
Fidgidair cws3600as1 washer leak
if you took them off then you have to reinstall a new set top seal with smooth side down
Apr 23, 2008 | Frigidaire CWS3600AS Top Load Washer
Spins really fast and loud and is leaking at bottom of tub where shaft goes in
buy a new washer .specifically a direct drive whirlpool,no belt. maytag washers are not what they use to be.
Jan 04, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
