Question about Frigidaire Washing Machines
Leaking from the drice shaft - Frigidaire Washing Machines
  • frank Bozick Nov 01, 2012
    Top load , Drive Shafy
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
I thought I had oil leak from prop shaft but upon inspection shaft seals were not leaking but had bit of oil on bottom of casing is there another seal 20hp mercy
Three more seals. One on the shift shaft, another under the water pump and one more at the bottom of the engine on the main drive shaft. There is also a large o - ring on the carrier. Chances are the shift shaft seal is leaking.
Feb 05, 2017 | Light Outboard Motor Boat Bass Fishing...
1986 nissan pick up leaks out of sterring box
check to see if the leak is at the shaft that the pitman shaft attaches to. if it is the pitman shaft seal will need replacing. if its leaking out the input shaft, the part that attaches to the steering column, then this seal will have to be replaced. check the power steering hoses closely for cuts and leaks. you may have to wash the area to remove the oil to find the leak.
Aug 28, 2014 | Nissan Cars & Trucks
Moter leaks when filtering
Is it leaking at the motor shaft or where the filter gasket and pump housing bolt together? If between the two housings,then it may just be a matter of tightening the screws that hold them together. If it is leaking around the shaft, you will need to replace the mechanical shaft seal.
To replace the seal you will need to remove the housings and then unscrew the impeller from the shaft. There is a slotted end on the other end of the motor shaft for screwdriver. This will hold the shart still while you unscrew the impeller. The shaft seal is a precesion part so be careful when replacing it.
Let us know if this helps, Robert
May 16, 2012 | Craftsman 1 - 1/2 Hp Pool Filter Pump
Leak around shaft and verry heavy after long drive
leak around What shaft, drive shaft, CV shaft, etc???
If drive shaft, on rear whell drive vehicle, the transmission needs a new rear main seal!
Good luck
Jan 21, 2011 | Daihatsu Rocky Cars & Trucks
CD drice not reading CD
Spend $40 to buy a brand-new CD/DVD reader/writer, to replace the "dead" unit -- much cheaper than paying $25 to $50 for a technician to try to trouble-shoot and repair it.
Oct 19, 2010 | Gateway (5501580) CD-ROM Drive
Left wheel making scraping noise when turning
drice shaft coupling by the sound of it ,if it is ignore it it will run for years like this ,just an anoying noise ,the end on its own is about 90euros ,and easy to change but what you would be charged in a garage in america??
Aug 17, 2010 | 2006 Audi A3
When i get to 55 mph i hear i popping in the front.Ive replaced both cv joints and a wheel bearing,but it didnt help.Iinspected the spider gears but they were fine.I disconnected the front drive shaft now...
Check the front differential for proper spacing inside, also the bearings. Then check the homocinetic joint right behind the front diff. on the drive shaft. If all of them are fine, open the oil screw at the transfer case, drain the oil and check if there are some metal in it. After draining the oil out, use a flat screw driver, insert it into the transfer case (be careful!!) to locate the drive chain. check if there she is very loose ( if you can slide the chain more than 1/2" it need to be replaced). To rule out the transfer case, disconnect the rear drice shaft (U-Joint on rear diff. and then slide them out of the case), disconnect the front drice shaft right on the transfer case (U-Joint), disconnect the shifter and any wiring you find on the case, remove the bolts from the chassie and then remoce the bolts between the case and the auto transmission and slide the case backward till you have it in your hand. Install a new or rebuilt one the same way back, fill it with auto trasmssion fluid as told in the user manual. Do not overfill the case and do not use other fluid as in the user/service manual.
Oct 23, 2009 | 2000 Jeep Grand Cherokee
System disk error or non disk error, replace disk and press any key.
you have a disk in thecd or floppy which is not bootable, remove it and restart. and if no disk is in the drices you may have a bad drive.
Jul 31, 2009 | HP Compaq nc6220 Notebook
Dodge Durango 1998 5.2L Output Speed Sensor code P0720 Location
Its in different locations depending on if its 2wd or 4wd. For 2wd its in front of the drice shaft or for 4wd its in the tranfer case, just look for a white shape like box with wires plugged into it and you need a socket to remove it, iam not sure how much it is to replace as the cost varies at different shops.
Jun 19, 2009 | 2000 Dodge Durango
Ford Escort Oil Leak on selector shaft
usually an "O" ring where the shaft comes out of the box but if the shaft is worn where the seal runs you may have to replace the shaft
May 07, 2009 | 1996 Ford Escort 4 Door
Washing Machines Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
