Question about Toshiba Satellite P15-S479 Notebook
Satellite not wanting to boot.... need help
Basically the laptop will not boot from the hard drive, and it will not boot from a cd also.... I don't know how to fix this issue and need serious help! If you can help I would greatly appreciate it, I also keep getting a message "Intel UNDI, PXE-2.0 (build 082)
Copyright (c) 1997-2000 Intel Corporation
For Reatek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM."
  • laptop4sa953 Jan 04, 2009
    Done all that and still nothing, I'm honestly not sure what to do, but I'm getting very annoyed. Any other ideas? It started to read discs and was working perfectly, while I was trying to reformat then it just stopped working again and posting the same message.
    tried all of them same problem, message popping up about the PCI fast ethernet controller, don't know what else to do, says hardware company is realtek, I guess I need a new motherboard.
  • 176 Answers
Disconnect any USB or other external drives or network cables connections
Boot to your BIOS (F2) menu and make sure the boot sequence is set to boot first on HD or CD ROM (whichever you prefer).
Posted on Jan 04, 2009
  • Ed Deguzman
    Ed Deguzman Jan 04, 2009
    Does it POST ? Make sure your HD is properly installed and enabled in BIOS. Try another similar HD and if that boots up then your original one is going bad and its not the system.
How can i go in boot option
Normally when you power on your Toshiba Satellite laptop it attempts to boot the operating system installed on its hard drive.
In some instances you may want to boot the Satellite laptop from a different device, such as an operating system installation CD or a USB drive.
The boot order doesn't have to permanently be set to the hard drive.
It's possible to access the boot order before the operating system loads and change which device is set to boot first.
Turn off the Toshiba Satellite laptop.
Turn it back on immediately and wait for the "press the F2 key to enter Setup" entry to show up on the screen.
Press the "F2" key to access the Toshiba Satellite's BIOS menu.
Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Scroll down to the option labeled "Boot Priority" and tap Enter.
Check through the list of devices and locate the specific device you want to use to Boot your Toshiba laptop, such as "CD-ROM," "USB" or "LAN."
Highlight the name of the device in the list and then tap Enter to make it the top boot priority.
Use the right arrow key again to scroll over to the "Exit" BIOS menu.
Tap the down arrow key to highlight the "Save and Exit" option.
Press Enter to save the new boot order and restart your Toshiba Satellite laptop.
Repeat the procedure when you want to change the boot order back to its original setting.
How to boot your Toshiba PC from CD-ROM, LAN, or diskette
Toshiba support
Aug 02, 2013 | Toshiba Satellite 2415-S205 Notebook
I dont know how to set boot option?
Normally you want to boot from the CD/DvD drive 1st then the Hard Drive 2nd. This is the best way because if the hard drive ever goes bad you can put a operating system disc or repair disc into the drive and boot from it.
Just be careful that when you boot the computer you don't have a music cd or movie dvd in the drive otherwise you might get an error messages saying unbootable device.
May 13, 2012 | HP Compaq nc6000 Notebook
Bios boot screen comes up
Bios Boot Screen? OK, You don't boot from the Bios, the Bios has settings to let you control where to boot from the Hard Drive, the DvD/CD drive, the USB Port or a LAN (Local Area Network). So, what exactly is your screen showing when you press the Power Button to boot it?
Apr 07, 2012 | Toshiba satellite c660
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Hello.. I need some help. I am using toshiba satellite a1O system laptop was fyn till nw..all of a sudden windows doesnt load..when i turn the power on, the toshiba logo is shown..then black...
First thing you do is to see what hard disc installed in your laptop. You can check that by checking it in your bios system. To check in your bios system first turn off your computer then press delete while your laptop is booting up. Then you will see if there is a hard disk detected in your lap top if there is a detected hard drive this means you have a problem in your windows installed in your lap top.
There is also a reason why those message appear if the first boot of your laptop is the CD/DVD ROM. Check you CD/DVD ROM if there a CD inside this may the first on to read while the laptop booting up. Remove the cd inside your CD/DVD ROM. Then restart your laptop. Check your hard disk connector it may have some loose contact thats why your laptop did not recognize the hard disc.
Hope this can help keep on touch with fixya. Hope to hear some testimonial from you. . .
Aug 12, 2011 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
If you want the computer to boot from the CD, you need to tell the computer to boot from the CD. At start up the computer runs through each device one at a time and tries to boot from it and it will boot from the first device that has a boot log. Right now your computer is set to boot from the hard drive before the CD drive.
Always back up your computer before going into the systems bios menu.
After a backup, upon starting the computer, press F12 when the bios selection appears shortly before the operating systems starts. Once in your bios menu, go to the boot order and tell your computer to first boot from the CD then your hard drive; then your disk drive if you have one.
After you are done, you can go back into the bios menu and change it back to booting from the hard drive first.
Feb 28, 2010 | Toshiba Satellite P205-S6287 Notebook PC
I hawe problem with boot from cd..
try going into the bios and checking that the hard drive is set ti IDE,
I had a sililar problem. mijoda
Jan 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite a135-s4427 Boot Manager Missing
its not the hard drive my frined, its the boot loader it has been deleted or it has been compressed the only way to fix this is to use the recovery cd you have, to boot from cd-rom you need to go into bios which is usualy F2 or F5 key, then under boot manager or somthing is the primary and secondary boot, change the primary to CD-ROM, then save it and restart then it should boot from cd-rom then you have do a start-up recovery.
Jan 22, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite P15-S479 Notebook Logo
455 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
