Question about Gaggia Titanium Espresso Machine
Ventilate? gaggia machine coffee
Have been disuse for about 3-4 years, since moving home, as no where to put it....now I have found a perfect spot, and pull Gaggia machine out of the box and deep dleaned everything even the coffee beans pieces left inside the grinder. (small hoover sucks everything out, (even the trap door)) Filled first fresh water into he tank and switch on, it's started working with "RINISING WARMING UP" then it's changed into "VENTILATE" read through manual to find out, what VENTILATE meaning, what's wrong with it?. said something about the water block, air flow etc*....no luck - tried to find help online,, no avail. seen some videos, something to do with a water pump at the back of the tanker hole where the they takes water from the tank. but the problem is where do I find the water pump thingy(!) or there's another solution to this? *I also turned the knob on rightside, to get steam out of the nozzle, BUT only hot water coming out. no steam. HELP...dying for a fresh brew of coffee(!)
  • 109 Answers
SOURCE: titanium ventilate issues
Remove the milk frother,checked to see if it is blocked.
This can cause the machine not to ventilate correctly.
They tend to block with old hard milk.
Posted on Aug 26, 2008
  • 1089 Answers
SOURCE: ventilate warning came on and machine no longer works.
Hi The first thing that I would check is the tip of the steam wand for a plug. If that is clear then I would suspect a clogged flow meter. If you can get the flow meter out it twists apart and don't loose the parts and the dot on the turbine goes up. Clean out the small opening on the bottom pipes where the hoses attach. Look inside and make sure that they are clear before reassembling.
Posted on Jun 14, 2009
EsWorld
  • 1618 Answers
SOURCE: Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
Posted on May 04, 2010
Testimonial: "Thank you very much! It functions now!!!"
  • 1089 Answers
SOURCE: No water comes out on ventilate. At first, the
Hi
It should take about 45 minutes to an hour to properly descale the machine. If it only took a couple of minutes you really didn't descale your machine. If you used the powder it has to disolve completly before descaling. The best way to descale is with the descaler in the tank. Turn on the machine and run about 8 ozs of water-descaler through the wand and then turn off the machine. Wait 10 minutes and repeatthe last procedure. Do this until the tank is empty. When done with the descaler, rinse out the tank and put fresh water in the tank and run the whole tank through the wand. Then fill the tank and your ready to go.
Posted on Nov 13, 2010
ginko
  • 19396 Answers
SOURCE: Gaggia titanium ventilate will not go off try to
Hi.
Please read here the full troubleshooting to follow if you get Ventilate .
Regards.
Ginko.
Posted on Jan 23, 2011
No water comes out on ventilate. At first, the water was coming out very slowly, in drips. The doser or grind were not the problem, because even when I switched to Hot Water, it was still dripping. ...
Hi
Nov 13, 2010 | Gaggia Syncrony Compact Coffee...
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Fix ventilate problem on gaggia coffee machine
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
May 18, 2010 | Gaggia Titanium Espresso Machine
How do I ventilate my gaggia coffee machine
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 15, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony "ventilate"
May 04, 2010 | Gaggia Syncrony Espresso Machine
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Syncrony digital gaggia coffee maker leakage+ventilate message
Good luck
Feb 02, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
66 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
