Question about Linksys Wireless-G WRT54GS Router (e125894)
I am facing problem with foundry switch x424 . frequently its shutdown
    Sniper:
  • 87 Answers
Check the power supply, find a replacement supply to try, this might help.
Posted on Jan 11, 2009
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
I have a Toshiba lap of 2 yr old, now am facing the problem of it shutdown frequently when me using system. Please inform wts the actual problem and how can i repair it?
Hi
this problem some times caused from over heat..
so check the temperature of CPU , you can do that from bios setup, and this need change fan may be.
and another reason damage of windows , so try to install new one
Apr 30, 2011 | Computers & Internet
I am facing a problem with my toyota corolla 1989, it backfires, frequent engine shutdown mostly when the engine is hot but not overheating, i already replace my ignition coil, adjust timing and cleaned my...
Sounds like an intake manifold leak. Once the manifold gets hot the gasket leaks. I would check that first and the head gasket second. Are you getting any smoke, hesitation at all?
Feb 11, 2011 | 1989 Toyota Corolla 2 Door
I dont know where to find the password can you help me ?
By default, the CLI does not require passwords. However, if someone has configured a password for the device but the password has been lost, you can regain super-user access to the device using the following procedure.
1) Start a CLI session over the serial interface to the Brocade device.
2) Reboot the device.
3) While the system is booting, before the initial system prompt appears, enter b to enter the boot monitor mode.
4) Enter no password at the prompt.
5)Enter boot system flash primary at the prompt. This command causes the device to bypass the system password check.
6) After the console prompt reappears, assign a new password.
Feb 07, 2011 | Foundry Networks FastIron® Edge...
We have foundry edgeiron 2402cf switch and forget my username and password , what i shoud be made ?
Please follow the steps below to reset the password
1. Power Off and Power ON the switch
2. Immediately enter 'b' to go to the boot monitor mode
3. Do not Enter any password in boot monitor mode.
4. Enter boot system flash primary
5. You will be getting a prompt as 'FastIron>'
Please set the new password as below:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password admin
FastIron(config)# write memory
Your new password is set now as 'admin'
Best Regards
Nov 10, 2010 | Foundry Networks Foundry EdgeIron 2402CF...
Not booting
power cycle -if poe try connecting voip phone via cat5 to port 1 or 24 then power cycle
Nov 25, 2009 | Foundry Networks Foundry FastIron Edge...
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron(config)# enable super-user-password test
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Sony Ericsson w580i shutdowns automatically
Dear
I think It's ur battery fault,ur mobile charging draining Quickly due to battery malfuction
As far my concern u better change ur battery
Thanks
Mar 19, 2009 | Sony Ericsson w580i Cellular Phone
Linksys Wireless-G WRT54GS Router (e125894) Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
