Question about Samsung SV5000W VHS VCR
Samsung SV-5000W VCR. Voltage regulator?
I have a Samsung SV-5000W VCR. I am on 110 Voltage in the states.
I used it on 220 Voltage in Belgium. Is there a button I need to push to set the voltage for 110? I could not locate one.
Thanks.
Ray
  • mr cicmo May 11, 2010
    Hi There, Did the unit ever work in the states before?
    Let me konw, mr cicmo
This unit has a universal power supply that automatically detects proper voltage. No buttons or adjustments required, just plug her in.
Posted on Feb 21, 2009
I cant plug my 120v input vamp2 power adapter into a 110v output voltage regulator its dont works
I don't understand why you are plugging this into a 110 volt regulator.. If by chance you are trying to run this from 220 volt power, you DO NOT use a regulator or a converter intended to run hair driers and appliances. You need to use a step-down transformer from 220 to 110 or 240 to 120.
The V\Amp2 is a switching regulator and it will NOT like to be run from another switching regulator such as found in those cheap appliance type convertors.
Here is the type you need: http://www.world-import.com/tc-100a.htm
Jan 07, 2011 | Behringer VAmp 2 Power Supply
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
Samsung VCR SV-5000W Tracking Problem Symptom: I've used Maxell VCR Head Cleaner VP-100. Still having small white streaks across screen. I can apply small amount of pressure to bottom or top of VCR deck...
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Nov 26, 2010 | Samsung SV5000W VHS VCR
Blinking white sparks during playback. My unit has this problem during playback, and I discovered that the SV-5000W has the same problem too ( see http://www.fixya.com/support/t151239-major_dropout ). At...
I looked at the link provided and there was no cure mentioned. From my experience with VCRs in general, I would suspect a flaw in the video pre-amp circuit used for playback. This could be distortion. Without seeing the actual unit and examining the signals on an oscilloscope, I can't be sure where the problem exists. It should be fixable however. Something as simple as a bad filter cap at the heads could cause this as well. The signal levels at the heads are extremely low. This unit requires test equipment that the homeowner is nit likely to posess. I would take this to a service shop.
Dan
Oct 11, 2010 | Samsung SV7000W VHS VCR
110 to 220 conversion
a converter plug should be fine
Jun 01, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Voltage on Acer Aspire One -110 - 220?
It is 100 - 240 V.
All you needs is the Votage adapter, no converter needed.
Acer Aspire one rating 11.1V laptop battery. Charger Specs: Input Voltage: 100 ~ 240V AC 0.24~0.60A 50/60Hz Output Voltage: +12.6V DC Output...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 14, 2009 | Dell Wireless Keyboard Optical Mouse w0147
HP laptops power supply
Well, as a rule for electronics:
The United States and Canada use 110-volt electricity.
Most countries outside North America use 220-volt electricity.
Unless your appliance is dual voltage, you need to use a "converter" or a "transformer" to change the 220-volt electricity into 110-volt electricity in order to use a 110-volt appliance.
If your appliance is dual voltage, you can switch it to work on 220-volts, without a transformer or converter.
HOWEVER
Desktop units have a selector switch for 110 / 220 volts., which is done away with in the case of laptop one's which sense the input voltage and regulate accordingly.
I think your main concern is just that you have an adapter for the plug to go into the wall outlet.
Hope that helps :)
TM
Apr 15, 2008 | Computers & Internet
VCR Samsung SV-5000W
You should take off the top cover with the set unplugged and see if there is a main fuse that popped. If there is, put in another fuse,. If that blows, then your going to need to have the power supply in this unit repaired. Good Luck
Dec 28, 2006 | Samsung SV5000W VHS VCR
Samsung SV5000W VHS VCR Logo
343 people viewed this question
Henry  Thomas
Henry Thomas
