Thermostat fault on switch
Ring stays on full power
Thermostat didnt fault on switch.we chack have power go in to cpu boerd
Posted on Nov 01, 2012
Hob rings glow then go out every couple of seconds? They stay glowing only when the dial is above 4
this is normal thermostat will switch off and on at low setting to maintain the temperature you set it at.At full power it will stay on.
Feb 24, 2015 | Cooktops
Boiler not responding to thermostat
The thermostat controls the gas valve is this sticking open , There must be a over heat that should cut in . Rebinded ??
May 07, 2017 | Honeywell Programmable Thermostat Heater
Belling 665 halogen ring faulty
You would need to study a circuit diagram for the stove to figure out where the fault is probably to be found and how it works or alternatively take it apart and follow the wires making notes as you go.
It is true, obsolescence and unreliability and a shorter lifespan is often built in to appliances and other things. Part of the reason is sensible designs using quality parts and engineering are too expensive and so good designs are production engineered (corners are cut) to save money, usually introducing problems and unwelcome "compromises". Often sophisticating the design using cheaper methods are used to overcome problems caused by production engineering.
One of the big problems with stuff designed to have a shorter life is the replacement parts needed to make them last a bit longer are usually priced not to sell.
Apr 05, 2017 | Kitchen Ranges
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
May 11, 2011 | Honeywell Programmable Thermostat Heater
I removed the Ground Fault Interrupter plug from my new GE window air conditioner to fit it in my camper, i put a normal AC plug on it now the thermostat stays on all the time. David
First, the GFI was placed in the system for a reason. On ANY part of an HVAC system, if it has a safety, you NEVER remove it. If you place a regular plug on it, I would replace the breaker that feeds that circuit with a GFI breaker. This will still give you the protection it needs without compromising safety at all. As far as your thermostat, does it have batteries in it or is it ran off your power input. If you have no power to your system and your thermostat was off before, but now you removed the GFI and the thermostat stays on, I would think you have a battery back up that will lock out the thermostat on a ground fault.
Sep 28, 2010 | Heating & Cooling
Fridge compartment freezing
First of all switch off the fridge and allow all the frost to clear off Then reduce the settings on the thermostat and switch on the fridge. If the fault stays then check if the compressor is shutting off , if not your thermostat can be faulty. Also if the timer is not working then frost can build up and reduce cooling. so check this out before you confirm. Repeat the shut down when the frost develops and do your settings/corrections before switch on. Only then you can confirm on the fault. Hope you try this out. Good day
Aug 10, 2010 | Westinghouse Refrigerators
I have a electric baseboard heater and when I turn the thermostat up, it heats for awhile and then the heater stops throwing heat but never reaches themperature. Changed thermostat and still the same...
you either have an overheat switch opening up prematurely or a bad connection that faults when it gets hot. Check all connections with the power off and try jumping out the safety switch to see if the heater stays on.
Feb 28, 2010 | Honeywell Heating & Cooling
2 of 4 ceramic rings do not respond to lowering the heat setting
You need 2 new temperature regulators fitting.
Quite a common problem..
Thanks
Plz rate solution
Dec 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
