My laptop often die for no reason, and each will be turned on, always appear a had to check. When I let it to do the checking, my laptop is completely dead and can't turned on again. The internal
Intel Core2 duo processor T6600 (2.2 GHz, 800 MHz ESB, 2 MB L2 cache) , Intel GMA 4500MHD, 14.0" HD Acer CineCrystal LED LCD, 1 GB Memory
  • 7,627 Answers
Is the laptop getting good air flow to cool? if it overheats the machine will shut itself down to protect the components. Do you use the laptop on a soft surface that restricts the flow of air? If not try a Laptop cooler. Your question/statement is a bit confusing. Could you clarify.
Posted on Nov 01, 2012
3 Suggested Answers
shakeelm
  • 224 Answers
SOURCE: hi me imran i have acer travelmate 5720 windows
You can download all drivers and additonal applications from the link below. Enjoy..
http://support.acer-euro.com/drivers/notebook/tm_5720.html
Posted on Mar 08, 2009
irfanview
  • 37 Answers
SOURCE: Which is better laptop deal?
Hi !!
Ofcourse 2.4 ghz is better than 2.1 ghz but its not a very big difference if price difference is more than 100$ than go for first one else second one is good and the most important thing i want to mention is that it all depends upon your needs you havent mention for what purpose you are going to purchase. But both are enough for gaming, daily use and for techie as well.
Hope that helps
Thanks
Posted on Jul 10, 2009
Tip
This is a nice simple solution to a problem commonly experienced with Toshiba...
This is a nice simple solution to a problem commonly experienced with Toshiba laptops or notebooks. Please remember this is not a guaranteed solution as there may be other factors involved as to why your laptop is failing to start e.g faulty RAM.
However, this is a very common issue that appears with these laptops and hence the reason for the Tip. It is very simple to do, involves no cost and often resolves the problem without any further intervention.
If your Toshiba laptop has mysteriously turned itself off and is now totally unresponsive or appears completely dead and won't turn back on - then read on.
Symptoms:
  • Laptop mysteriously turns itself off and will not turn back on
  • Laptop appears completely dead/black screen/unresponsive
  • Laptop refuses to charge the battery when connected to the mains supply i.e. No charge light showing.
  • There may be a brief flash of the screen or power button when you try to turn it on but then it immediately shuts off again.
Solution:
  • If the laptop is still connected to the mains unplug it completely
  • Remove the battery from underneath the machine by releasing the locking tabs (or screws dependant on your version).
  • *Important*: With the battery removed - press and hold down the power button for at least 20 seconds. This is to remove any residual power from the laptop.
  • Reinstall the battery and plug the laptop back in to the mains.
  • Turn laptop on as normal and hopefully it should power up.
As stated at the outset, in some instances there will be other reasons as to why your laptop is not turning on. However, because these symptoms are a common yet often overlooked problem with this laptop, it is highly recommended to troubleshoot this procedure first before resorting to testing or replacing any hardware.
If the problem has failed to resolve using this simple step then please see my Hardware troubleshoot LapTop Will Not Turn On or Boot
This includes a video walkthrough to help guide you through the process.
Please do help by registering your vote for this Tip using the buttons below.
on Mar 06, 2010 | Baby Care
Tip
If your Toshiba Laptop Will Not Turn On
Symptoms:
Solution:
on Jan 25, 2010 | Computers & Internet
Mouse was turned off. How do I turn it back on?
Strange. There is no option to turn off a mouse. Mouse works togetehr with the touchbad.
Check if it's correctly inserted in PS2 or USB. If wireless, check battery.
Turn off and restart your computer.
By the way, wireless "mice" die suddenly with no reason.
Sep 11, 2015 | ASUS Computers & Internet
Appearing white dots on tv screen
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help. There are so many reasons for this fault. All are described in detail.
Apr 02, 2013 | Samsung 32 UN32D4000 LCD TV
A few weeks it appeared that the battery had went flat with no reason but started with jump leads. Now it won,t turn over and the whole dash flashed as if it had a short. Inside lights and radio are...
Sounds like the battery is completely dead. It's either a faulty battery(go and have it checked) or a dead alternator. To check if the alternator is bad, once the car is started, remove the negative battery cable, if it stays on, then the alternator is good, if it dies immediately, then the alternator is bad and needs replacement.
Aug 03, 2011 | 2006 Volkswagen Passat
I have purchased a Palsonic 81cm wide screen LCD TV/Monitor TV Model No: TFTV321FHD 2 Years ago. For the past 2 months my TV for unknown reasons will not start when I turn it on This can sometimes...
Take the tv back cover apart,check the tv power supply board,that the board where the power a/c cord plug into it.Check all over the power supply board,for dying parts call capacitors.The dying capacitors are alway bulging or puffing ups on it tops.U have all the tools and understanding basic electronic also can do basic soldering?Yes.Repalces all those dying capacitors,with new capacitors with same Micro Ferid but the voltages higher like 5 or 10 voltges for better heat resistance.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Mar 26, 2011 | Televison & Video
Hello my name is becca i have a 2000 hyundai accent it was fine one night the next day i went out to start it it wouldnt got a boost it started but once the ground cable was taken off it died in seconds...
Batteries sometimes die completely for no apparent reason even though they were working fine only hours beforehand. Try another / new battery and get the alternator fuse checked, because it should not be obviously split, and replaced if necessary because with the fuse out, the battery will not be recharged. The alternator charging rate appears to be OK but have it checked anyway.
Oct 29, 2010 | Hyundai Accent Cars & Trucks
Engine runs great but die's like the key is turned off
check all of the vaccum lines and check to see if your intake manifold is leaking and you fuel filter maybe clogged
Apr 27, 2009 | 1995 Ford F150 Styleside Regular Cab
95 MITSUBISHI 3000GT DIES FOR NO REASON
WOW That's weird and bad!
there should be lots of thing to be check on your car.
starting from battery, fuses, relays, solenoid to spark plugs.
fuel line, filters, and injector/carburetor.
if only your car looses power while driving then your fuel filter could be blocked. check and remove any dirt/blockages.
if starter (starting) fine, and car start normally, check the spark plugs.
Nov 06, 2008 | 1995 Mitsubishi 3000GT
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
