Question about Kenmore 15129 Built-in Dishwasher
Dishwaher will not start a cycle
Turn dishwasher on and I have to pull door open slightly so sensor will start a cycle.
  • 530 Answers
You probably have bad door switches. Is it hard for you to open the door after it is shut? You can access them by opening the door and you will see some torque screws usually you only have to take the ones out of the control panel to access the microswiches in the door lock. sometimes there is only one but likly you have 2. sometimes just the microswitchs can be replaced but if theplastic holder is broke you have to replace the whole assembly. I hope this helps
Posted on Jan 04, 2009
  • 311 Answers
If your having to wiggle or move the door to get it started then its your door latch/ can take apart and inspect or just get new ang install.God bless ,tom
Dishwasher not completely drying
The dishwasher does not dry the dishes, it is the residual heat remaining from the washing water that dries the dishes.
Once the washing cycle is over, opening the door and pulling the top drawer out slightly to keep the door ajar will create a small opening which allows the steam to escape and the dishes then dry a lot quicker.
Jun 06, 2014 | LG LDF6810ST Stainless Steel Built-in...
Dishlex 300 blobal dishwasher. have set dishwaher for normal wash as usual. All lights are one but dishwaher will not start. help please
It is likely the door switch is not engaging properly. Check the gasket is set properly and the door is closing when you shut it. Also confirm if it is not on delay start.
Feb 13, 2011 | Electrolux Dishwashers
My whirlpool dishwasher will not start. It beeps, drains & flashes Err4 on the screen.
If you are using tablets that have rinse aid as well as rinse aid, it causes to many bubbles, these get sucked down the two little outlets (located at the bottom of the dishwasher door, easy to see if you open the door completely) and make the water level in the base seem higher than it actually is which triggers the over flow button. Now to fix it is SUPER hard....NOT! Just pull out your dishwasher, and tip it back slightly. The water stuck in the base will trickle out...not much but will take 5-10 mins. Then turn it on, run on a rinse cycle to be sure its all gone!
Sep 28, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
My Maytag dishwaher is three years old. It will not start. The only button that will work is the cycle slection.
Above is your link for your manuals, use these along with the DIY self help repair website below, to troubleshoot and hopefully repair the problem.
Now this fix below may not work, but it is always worth a try, if it fits the criteria. Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You should NEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Jul 05, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
Fishcer and Paykel Dishwaher is continually beeping but not starting the cycle. It has water in from previous part finished cycle when the beeping started
You have a leak. When the bottom sensor detects the wetness, it won't allow to start.
Pull out the tube put some small tower unser the tube to dry out water.
Unplag power cord for 24 hrs to let the sensor dry out.
Then you will be able to start.
However if you don't replace the lid seal the leak will happen everytime a cycle starts and you will have the same problem over and over again. Good luck to fix the lid seal.
Aug 08, 2009 | Fisher and Paykel Dishwashers
Zug Adora 12s Dishwasher
Perhaps the solution to your problem can be found in the User Guide-
Your model number appears with two suffixes; WW and BB thatmay only be color codes but user guides (which appear to be identical) areavailable for download from GE’s site:
Oct 02, 2008 | General Electric Adora GHDA670N Built-in...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
New dishwasher
Having same problem + won't dry. Looks like this is a crap dishwaher.
Nov 06, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Kenmore 15129 Built-in Dishwasher Logo
90 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
