Question about Acer Aspire 3680 Laptop
Attaching external monitor to acer aspire 3682wxmi
I am trying to add an external monitor to the above laptop and it continually starts in safe mode, have tried various suggested options but as laptop is in safe mode have very limited access.
Reason for attaching monitor is screen is totally broken and uselss
I wouldnt put something like that in, sounds like your having a driver issue,
Posted on Jan 04, 2009
Asus g50 has no boot mgr, and when i try to reload windows it wont recognize any hdd?
Try booting in safe mode first.
Start your PC and as soon as it starts, keep pressing the F8 key continuously. If a screen comes up with an option to start in safe mode, go to that option. If you can boot to that option, go to start-type in system and look for system restore. Click on that and follow the instructions.
If you can't do that then look here:
http://www.tomshardware.co.uk/faq/id-1945283/tutorial-fix-bootmgr-missing-error.html
Dec 10, 2014 | ASUS Computers & Internet
On 5 sec after off laptops
You could try to start the computer in safe mode, to see if this is driver issue. When starting computer, press down F8 and select safe mode startup. If monitor works in safemode, try to reinstall display driver.
Also you could check with external monitor, to isolate where the issue is related to. If external monitor works fine, it might be HW problem with your laptop monitor.
May 01, 2014 | Dell Vostro 1015 Laptop
I have a dell laptop that I want to add a second monitor to. My monitor is a HP L1755 and my laptop has Windows 7 Ultimate on it. I can not find a driver for this... any suggestions?
Hi there, if i read you correctly you are trying to connect external monitor on laptop. As you use old Monitor for this you can probably establish only VGA connection . For this you dont need any special drivers if you use VGA external connector on laptop. You just need to find out right combination on keyboard to activate external monitor to be activated or right click on desktop then properties and display option multiple displays. Of course when you manage to activate mode for external screen please use lower resolution like 1027*768 for second display aka monitor to test .Cheers
Sep 15, 2013 | Samsung 941BW LCD Monitor
My laptop isn't working . Turns gray then white with various color lines
If it's new return it. OR, Connect to a External Monitor, if the issue shows in the External monitor it's most likely the Graphics Adapter. Try booting to Safe Mode, do you see the same problem? Have you done ALL the Windows and Compaq Updates? Is it overheating due to poor air flow from the fan (bottom) and side vents? Has it been damaged?
Mar 28, 2013 | Computers & Internet
External monitor only works if I start windows vista in safe mode
First after you boot it up normally (not Safe Mode) can you move the mouse far to the left or to the right do you see the mouse. If you do see the mouse pointer you are running dual monitor mode and the laptop screen is set as the primary monitor. You have to run it in Save Mode and set the external monitor as the primary monitor. Hit the Start button then select Help+Support and in the search box enter "dual monitors". Read how to set up the primary monitor.
Second maybe you need to activate the external monitor. When laptops boot normally (not Safe Mode again) with a external monitor connected you have to hit the Fn (function) key (probably blue near Alt key) and some other number key (it probably has a blue monitor symbol on it) I'm not sure which one. This key sequence is a toggle sequence. In other words when you boot a laptop it goes directly to the laptop screen then the first time you do a Fn + number key combination it will turn on the external monitor and turn off the laptop screen the next time you push Fn+number key it will turn on both monitors (external and laptop screen) the third time it will turn on only the laptop screen and so forth.
Aug 19, 2012 | HP Pavilion dv7-1245dx Notebook
I have an NEC S970 laptop and cannot boot it
may be this can help you
if not contact me support@itindiasupportonline.com
press f8 goto enable vga
after login just set the resolution into 800x600 then
restart the laptop in normal mode
or els contact me
Oct 06, 2009 | Computers & Internet
External monitor looks like the computer is in the safe mode
If XP:
Start->Control Panel->Display->Settings tab->Screen resolution->move marker to "more".
If Vista:
Start->Personalize->Display Settings->Resolution->move marker to "high".
Mar 12, 2009 | HP Pavilion dv4000 Notebook
Screen does not work
Did you try to start in safe mode? Turn on the laptop and start tapping the <F8> key. This will bring you to a menu with different options and select ‘Safe mode”. If that doesn’t work, try connecting an external monitor to the laptop. You may have to select the video output to display on the external monitor by holding down the blue <FN> key and pressing the blue CRT/LCD (located on one of the <F> keys, like F8,F9, etc..).
If the laptop display works in safe mode, then you probably have a video software driver problem.
If the display works on the external monitor in normal mode, then you probably have a problem with either your LCD panel.
Hope this helps.
By the way, the "9" led with the pad lock means your "Num Lock" is enabled.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 22, 2008 | Dell Inspiron 6000 Notebook
Acer Aspire 3680 bot issues
The problem is it is defaulting to lcd and not the external monitor
<FN><F5> to toggle to external
Jun 03, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3690-continuously reboots then checks harddisk several times, every time I start this Laptop
First remove any new, or unnecessary hardware, extra mouse / keyboard / monitors / dongles / and even the battery.
Try again, and if possible, get into 'safe mode' by pressing F8.
If it is stable in safe mode, you at least can try removing devices under, START / CONTROL PANEL / SYSTEM / HARDWARE / DEVICE MANAGER. Then whilst disabling various devices, try booting again into normal mode, and obtain a new, AND correct driver for whatever piece of hardware was deemed to be at fault.
Erik.
May 14, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3680 Laptop Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
