Question about Hotpoint Washing Machines
Hotpoint first edition 800
Washer isn't spinning i can hear the motors attempt it, which suggest to me either a broken belt or slipped belt or perhaps the brushes on the motor. Can anyone add there 2 cents on if its something worth attempting to fix. thank you all
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Does the machine agitate?
Posted on Nov 01, 2012
  • 38 Answers
SOURCE: Zanussi IZ12 Washer won't spin.
check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
Posted on Jul 24, 2007
watugot
  • 290 Answers
SOURCE: Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Posted on Oct 21, 2007
SOURCE: washer won't spin but motor runs and belt is not broken
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Posted on Oct 29, 2007
centurionin
  • 20 Answers
SOURCE: kenmore washer 70 series 20702 will not spin or drain
it sounds like your coupler is broken, with the machine unplugged and with help pull the washer out and then tilt it back. look between the motor and the transmition for a back disk sandwiched between 2 white disks. if it is gone then you need to replace the coupler. it is a medium difficulty job, you need to take the shell off in order to do the job.
Posted on Dec 19, 2008
Maytag317
  • 1136 Answers
SOURCE: The drum on my maytag epic z washer will not spin.
Hi, The belt must have came off. Remove the access panel in the front and see if the belt broke. If the belt is off, see if there is an access panel in the rear that will help you get to the belt easier.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 04, 2009
Frigidaire front loading washer drainage
Hello - Is the washer draining or not draining? If it is not, this particular issue could be caused by a variety of reason. I would suggest trying the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then that means the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Oct 01, 2012 | Frigidaire Washing Machines
Drum wont turn but the moter does
Hello Deanna - This particular issue could be caused by a variety of reasons. I would suggest trying the following steps:
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
F08 flashes near the end of cycle and wont drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you. Best regards and thanks for reading
Apr 12, 2011 | Hotpoint Ultima WF860 Front Load Washer
Drains fine just wont spin
Mar 28, 2011 | Frigidaire Affinity ATF7000ES Front Load...
Washing machne works ok washes drains but wont spin
Mar 03, 2011 | Hotpoint WMA32 Front Load Washer
Wont spin and drain water out
Feb 26, 2011 | Kenmore Elite 45986 Front Load Washer
My washer fill with water,but wont agitate spin or drain dial clicks to change cycles thats about all please help.No signs of broken wires
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. Now, the wash, spin, and draining is controlled by the motor drive. You need to check the belt. Check to see if the motor is bad, not getting power, or not getting a signal from the control board.
Feb 08, 2011 | Magic Chef CAV2000 Top Load Washer
I have a kenmore 70 series washer and it was working fine until one day i came to it after washing my clothes and it was still filled with water. So it wont spin or drain the water out. When i start the...
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Feb 02, 2011 | Kenmore 24932 Top Load Washer
Toploading Hotpoint washer does not spin. Can hear machine attempt to spin but nothing happens? Help!
Sounds like the drive unit has broken or slipped a belt. Remove the front cover of the machine with screws that are on the rear side of the frame and along the top below the controls, the entire front cabinet will pivot out and away from the frame. You can then see the motor and drive unit and access the problem area. It should be pretty apparent. Hope thias helps.
Jul 19, 2009 | Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
