Question about Korg Music
Factory reset ps60 - Korg Music
    Novelist:
    Champion:
  • 225 Answers
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
Sep 27, 2017 | Alesis Music
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
Sep 16, 2015 | Roland Boss Gt-10 Guitar Effects Processor...
My korg ps60 shuts off after using it for a while . The led screen goes white with no response
Open it up feel the transistors and chips one is getting hot make a cool element for it from aluminium or use ney arctic silver padte between the transistors and the cooling plates
Nov 08, 2014 | Music
What screws need to be removed to get inside the keyboard to replace power supply input jack
Flip the keyboard on its back and remove all screws with an arrow.
If no arrow, remove all on outside edge.
The jack should be easy to replace but you may need a soldering gun.
May 07, 2014 | Korg PS60 61-Key Performance Synthesizer
Factory reset Behringer FBQ2496
After my FBQ 2496 began to go "wild", it finally went blank with a ticking sound. I tried pressing and holding the "Reset" and "Bypass" buttons, simultaneously during power on. It worked after 3 or 4 tries.
Feb 24, 2014 | Behringer USA FBQ2496 Ultra Fast 24 Bit 96...
My Korg PS60 sounds veey low with Headphones . i didnt plug it to an Amp yet ( Id just receve it yesterday ). Headphones Sounded also just in one side. I had to buy a Plug Stereo converter . Is this...
It is NOT normal... Apparently one side of the audio drive is bad, Take it in for WARRANTY repair immediately. Also read your manual in regards to "Panning" and any settings for it.
Nov 08, 2012 | Korg PS60 61 Portable Performance...
My ps60 has a high freq noise with a regular pulse pattern it does this thru mymixer and also when i plug it direct into amp cheers Brian Garbutt
Hello Brian, It could be a ground loop problem, I usually get something similar when connecting a laptop to an amplifier. You can purchase ground loop isolators from car hifi places which are used to take ground loop problems out of car audio systems. They are very cheap so maybe worth trying this first. I got one for £12. They have stereo RCA input/outputs and require no power.
Hopefully this is of help to you.
Aug 08, 2011 | Korg PS60 61 Portable Performance...
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
The Sustain pedal does not work.
When push comes to shove, a factory reset never hurts.
Assuming you'd like to proceed with a factory reset, follow these steps:
This procedure makes it possible to restore the S08 to the original factory-installed Internal Voices, Multis and System settings.
WARNING: The current settings for all Multis and User Voices will be deleted. If the current settings and data are not expendable, create a backup before executing the Factory Reset.
1) Press the [UTILITY] button.
2) Press the [JOB] button. The 'FactorySet' screen will be displayed.
3) Press the [ENTER] button. The 'Sure?' message prompt will appear.
4) Press the [INC/YES] button to execute the Factory Reset. The 'Completed!' message will be displayed to indicate the procedure has been successfully executed.
5) Press the [EXIT] button to return to the Utility Mode.
Oct 14, 2017 | Yamaha Full-Size Keyboard
Music Logo
249 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
