Question about HP OfficeJet 710 InkJet Printer
No manual i recently received a 710 from a friend, it works fine, but i can not setup the fax/date-time functions, because i have no manual. where can i find one?
  • 385 Answers
This link directs to a page for setting date-time for a number of hp printers including officejet 700 series: Here is the link for the manual. Hope you find what you're looking for between two links. Thanks, Lolita
Posted on May 17, 2007
How do I set the date and time for out-going faxes?
Press the MENU or SETUP button. Scroll to FAX SETUP, then just go through the sub-menu items to set the date, time etc. You should be just fine after that. Also, you can go onlline to Click on the Support & Drivers tab, enter your printer model and hit GO, then just follow the prompts to find your manual. Save the PDF manual to your desktop. This will come in handy for most of these general type questions. Happy faxing!
Apr 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Can't figure out how to reset date/time/header information on faxes & reports.
After you change to fax mode, press menu and then general setup for the date and time. After that you scroll down to fax setup to change the header.
Oct 16, 2009 | Brother Multi-Function Center MFC-240C...
Date received at top of page.
you cant you are going to have to go get a time/date stamp machine and put each one through it
sorry i couldn't of more assitance but your machine does not allow for that feature
May 04, 2009 | HP LaserJet 3050 All-In-One Printer
Incoming faxes do not show time or date
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Date and time wrong on the journal
to reset the time and date on the machine you need to hit
Function-7-1-start- then adjust the time and date and hit start then stop
Com journal after every fax
Function7-4-start-1-2-start-2"should says always" then start stop
receive time print." puts the time and date of your machine of the fax..example if your receiving a fax from new york and your in california it will put your time and date at the bottom.
Function7-4-start-9-start-2"should say valid" start then stop.
as for why your losing your time and date all the time is because the battery if dead on the machine.
hope this helps.
Jan 07, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
Date and time adjust
to fix the time and date press function-7-1-start-fix the time and date-start-stop
good luck
Apr 17, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
HP OfficeJet 710 InkJet Printer Logo
73 people viewed this question
Ben Johnson
