Question about Pioneer Audio Players & Recorders
How to setup the channels in pioneer cxc8885 - Pioneer Audio Players & Recorders
How do I setup my channel memory on my pioneer audio/video receiver VSX-D906S
Try Googling (Pioneer)(VSX-D906S)(manual) without parens to get instructions.
Nov 20, 2017 | Pioneer Audio Players & Recorders
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
I have a pioneer elite vsx-03txh reciever and all my speaker indicators light up except for the subwoofer but my sub still works and all my other speaker channels light up for 5.1, 6.1 and 7.1 but not the...
And the problem is? Your receiver setup determines what gets sent to the sub from ANY source.
The indicators are to inform you of how many channels are encoded into the digital source. If a source-dependent LFE channel is encoded, it should light up. Check the source's setup to make sure it knows you have a sub and is configured for a discrete LFE channel.
Feb 12, 2010 | Pioneer Elite VSX-03TXH Receiver
I have a model number sd-p503p-k i dont know how to add channels after channel 65?
You probibally need to re-scan your available channels. The TV goes through and grabs all of the available channels that it sees so you don't get any all static channels while your surfing the tube. The manual is actually about 35 megs so I cannot post it here, but here's what it says; - Hit Menu
- Select Setup
- Select Channel Setup
- Select Auto Channel Preset
- Select Antenna and change it to A or B, whichever one your using.
This should fix your problems, unless your area doesn't have channels past 65. If that's true then everything I just wrote is irrelevant, but there ya go!
Oct 28, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Receiver won't let volume go higher than -7 dB
Actually, -7 db and above woul be quite load.
Anyway, I am not very familar with the Pioneer GUI auto setup. But, am aware of how AVR are set-up.
If you have set up the home theatre by auto/manual setup then please check the channel levels whether any of your channels settings is at +7.0db.
If so, reduce this setting where it more +7.0, then you would be able to raise the overall main setting from the volume control to go higher than -7db.( by as much as you've lowered the particular channel setting)
Please do let me know if this helps.
Apr 29, 2009 | Pioneer VSX-1018AH-K Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
No sound out of rear speakers
Depending on your setup. you may have a "bridge" option which allows you to bridge channels. Check each channel with one speaker at a time. also each channel may have individual fuses. Check your channel fuses first, and test each channel with one speaker. GL
Jan 02, 2018 | Pioneer DEH-P77DH CD Player
Center channel
Just to rule out the easy solutions, have you made sure no settings changed? Make sure that you didn't accidentally turn off any surround sound settings or turn off the center channel in the MCACC setup or the like (I have the VSX-D814, so your receiver should have MCACC as well). If you're sure no settings changed and the center channel should be working according to the receiver, then it would appear that the center channel amp went out in the receiver. You can either get a Pioneer service center to take a look at it, or if you're comfortable with electronics, I believe you can get the parts straight from Pioneer.
Dec 10, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer sdp4682k
try the RGB or the S-video out of the Direct TV receiver.
Nov 11, 2007 | Televison & Video
16 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
