Question about Dryers
Procombi 85he,cutting out on heating
Goes into lockout after 5 mins ,showing red,ihave already changed primery ntc,made no difference.
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Check the thermostats for continuity.
Posted on Nov 01, 2012
2 Suggested Answers
  • 107 Answers
SOURCE: Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Posted on Mar 13, 2009
Beko DCU8230 not heating up
Could be heating element failure
Feb 13, 2017 | Dryers
My 2006 scion xb keeps heating up already change the radiator,water pump, thermostat, fans and temp.sensor but just keeps heating up already took it to 5 different mechanics just cant find the problem
How are you determining that it's over heating ? Temp. Gauge ? Do the cooling fans turn on ? 5 different mechanics ? Did any of them hook up a scan tool , to see what the coolant temp is . Use a inferred temp tool to see what it shows for temp.
Mar 26, 2016 | Scion Cars & Trucks
What would cause my car to cut off while driving?
Sounds like a power relay or breaker that is getting weak. Over time electrical components break down from heat. Without having a schematic cant tell you where to look!
Mar 07, 2015 | 1992 Honda Accord
My delonghi ECAM23.450 when turned on displays "heating up please wait" then nothing - sometimes it will show "general alarm" then nothing - the machine is clean and has not been used very often - any...
Check NTC sensor and heating element terminals. You should get resistance with multimeter or ohmmeter. NTC sensor should change resistance when you heat it up with lighter, finger or whatever heat source you have near by.
May 10, 2014 | Coffee Makers & Espresso Machines
I have an Indesit ISL70 and we seem to have developed a problem. Three red lights are flashing (water, filter, heat exchanger, all of which are ok) and the door won't open. Any advice?
Note:- The front NTC connects on the top edge of the circuit board - plug with two orange wires. The element and rear NTC are connected on the right hand side of the circuit board - this plug has 5 wires Blue, Orange, Brown, Red and Black.
1) The front NTC measures approx 500k ohms.
2) The rear NTC measures approx 500K ohms [red and black wires on the plug]
3) The resistance between Orange and Blue Wires is Approx 46 Ohms [This is one half of the element]
4) The resistance between Orange and Brown wires is Approx 46 Ohms [This is the other half of the element]
5) The resistance between the Blue and Brown Wires is approx 92 Ohms [This both parts of the element]
My machine has 2 devices above the element, one is an NTC the other is the safety cut-out. The safety cut-out is connected in the orange wire to the element common connection.
The resistance of the NTC's varies with temperature - so you may not get the figure I have quoted. The resistance reduces as the NTC warms up; if you remove the NTC connect it to an Ohm meter and warm the flat metal side with your finger you'll see the resistance go down - the drop wont be dramatic [after all your finger is not that hot] and is easier to see on a digital meter.
Measurements taken with the plugs disconnected on a digital meter... and don't forget folks MAINS PLUG OUT FIRST!!!!
Important.... there are some different versions of these dryers, so different readings may be obtained.
Dec 22, 2010 | Indesit IS70C Electric Dryer
No heating and hot water
sounds like overheat stat easy job to replace and do,nt cost the earth best of kuck
Oct 14, 2009 | Water Heaters
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
May 13, 2008 | JVC RX-6042 Receiver
Dryers Logo
112 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
