Question about Hitachi 43UWX10B 43" Rear Projection Television
43uwx10b turn power on, t.v. powers up then suts off in approx.
10 seconds.
  • Hitachi Master
  • 5,138 Answers
Replace Both of your convergence ICs STK392-110s use 180s, they are big black ICs will have part number on them. Parts 1-800-223-3205 Electronixs For MAT Electronics 1-800-628-1118
Posted on Jan 04, 2009
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
Unit comes on,runs for ten seconds,(w sign on page on screen)then turns off.
"Hello, Sounds like you have a bad monitor, or video cable, replace."
Nov 08, 2015 | Computers & Internet
Tablet wont turn on
If the tablet battery was left to drain completely, it may not turn on at first. Here is what to do. Plug in the charger and charge for 5-10 minutes. Then try again. If nothing, then press the power on button for approx. 10 seconds, and that should reset the circuits. Then try powering on again. Continuing charging the battery until full.
Jul 06, 2014 | Lenovo Computers & Internet
The Archos 10 1G9 - On the screen there is no second circle so that the tablet can be unlocked
Press and hold the power button for approx 10 seconds, and then release and then try turning the tablet on again.
Nov 22, 2012 | Computers & Internet
How to reset a password
Try 0000, that should be a default code.
If not then It is possible to reset and test the headset. Make sure that the
headset is powered off. Press and hold the answer/end button
and the on/off button at the same time for 10 seconds.
The headset will automatically turn off after approx. 10 seconds.
The next time you power on, the headset will go into pairing
mode as the first time you powered your new BT2070 on
Hope this helps.
Thanks
Apr 16, 2011 | Jabra Bluetooth Headset - BT2070
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Jul 14, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have a hitachi 43uwx10b and when I turn it on it will
its a bad capacitor , go to www.youtube.com and you can search for projection televison capacitor repair . and it will pop up with all kinds of video's for you to show you how to repair it yourself with a little soder and a sodering iron.
Mar 11, 2010 | Hitachi 43UWX10B 43" Rear Projection...
CANON MP830 is giving me an error code 5010. What does this mean and how do you fix it?
This error refers to the following possible problems:
1) Unlock the scanning unit: Before turning on the power, open the scanner cover, slide the release button to the "unlock" position and close the cover. Turn off the power for approx. 5 seconds. Power back on.
2) Reset the device: Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord). Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) Your MP 830 requires repair service.
Dec 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Power light turns on turns off continuously
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Jul 31, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
