Question about Lands Phones
Gigaset as200 no dialing tone
I have re registered the phone still no dialing tone ,comes straight on to voice message
SOURCE: STILL SAYS "PLEASE REGISTER"
I think this may be the answer. With multiple handsets reading "Please register" and a "working" base station (w ith dial tone). If you bring the remote units to the base station and place them on hte base, they will register and stay registered after you return them to the remote base. It doesn't say this anywhere in the instructions as it gives you the impression the remotes will register from their own base.
Posted on Mar 24, 2008
SOURCE: Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Posted on Mar 28, 2009
SOURCE: no dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Posted on Mar 29, 2010
popsgifts
  • 160 Answers
SOURCE: Has new battery, but no dial-tone,
Replacing the battery reset the phone to the factory defaults, which means you'll have to restore the connection to the base in Menu-Setup
***Don't forget to VOTE for the guys who take an interest in helping!
Posted on Apr 19, 2010
jviola
  • 9 Answers
SOURCE: continuous dial tone on phone line
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Posted on Oct 26, 2010
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
Phone can receive calls but not make them.
hello i have a solution, you need to change you dialing mode on the base option, the deafult is "tone dialling", change to "pulse tone " this fix my problem on my A495 gigaset.
May 16, 2012 | Lands Phones
Voicemail light keeps coming on
From att.com:
Q: What should I do if I my Message Waiting Indicator, stutter dial tone or light on my phone, is on but I have no new voice messages?
A: Make sure to check all message types when reviewing your messages (i.e. voice, email and fax).
Q: What should I do if my Message Waiting Indicator (MWI), stutter dial tone or light, is stuck on?
A: Power cycle (turn off/on) the Phone or Customer Premise Equipment (CPE).
Nov 18, 2011 | AT&T Corded phone
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
My gigaset 4015 has no dial tone. (My other mechanical phone does, so it is not a phone service problem.) On the screen there are the battery indicator (OK), RDL and MENU. The other usual symbols, time,...
I have exact same problem. Let me know if you find an answer.
No dial tone. I can call out and reach number (though no sound) so connections are there but just no sound.
For incoming calls, phone rings, pick it up, no sound.
Any solutions??
Dec 31, 2010 | Siemens Gigaset 4015 Cordless Phone
Cannot clear message on handset that says I have a voice message.
I resolved the problem but I'm not 100% sure of how I did it. If it happens again I'll try it again. I left the answering machine OFF so the Voice Mail would take any messages. A friend phoned and left a message in the VOICE MAIL, I knew this because of the broken dial tone when I went to make a call. When I erased his message the 'New Voice Message' displayed on the handset disappeared. I figure a previous caller hung up just after the voice mail picked up. It was not long enough so it did not register in the voice mail but somehow registered on the GE phone. Since there wasn't anything registered in the VOICE MAIL to erase the message was 'stuck' on the handset display. As soon as there was a message registered in the VOICE MAIL that could be erased it also cleared the message on the handset.
As i mentioned, if it happens again I'll try it to see if it works, until then I am not going to tempt fate.
Dec 24, 2009 | Uniden Cordless Phone
FLASHING BASE 1 - PHONE'S LOCKED
Unplug the batteries for 30-45 seconds. Reinstall, and attempt to re-register the handsets to the base.
Jan 26, 2009 | Siemens Gigaset 4200 Cordless Expansion...
No dial tone
This is the time that love cannot help with. Buy yourself a new home phone where the massages will pile up. erase all massages on your mobile phone. It is time to buy a cell phone which will record all masseges that you've received.
Sep 23, 2008 | Siemens Gigaset S455 Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
