Question about Toshiba Satellite A135-S2266 Notebook
POWER LIGHT COMES ON NOTHING LESS YOU CAN HEAR THE FAN RUNNING
  • Toshiba Master
  • 7,627 Answers
Need more info. It does not boot? What does it do when you re boot? Be as specific as you can.
Posted on Nov 01, 2012
The system will not boot up
try removing the battery and power cord and then reinsert them and try starting it up again
Oct 11, 2012 | Sony Computers & Internet
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
I have a slim ps3. When i'm playing for 2 hours or less it just suddenly shuts down... No lights come, Nothing! Have to plug it out then back in to get it going, Any ideas??
hi, make sure the cooling fan is working, if it doesn't the console shuts down itself to preotect the system, you can get your ear really close to the fan and listen to see if it makes any noise, check it often because sometimes it doesn't kick on till the console is getting hot, if you can't hear the fan running it could be your problem.....
Oct 04, 2010 | Sony Playstation 3 (PS3) Console
My coleman evcon fan motor does not come on. I put the thermostat to on so the fan would run but it will not come on. The rest of the furnace runs properly.
Did you check to see if you have power or fuse blown? If it is a furnace/ air handler and you are comfortable with electricity. Turn
Power off, remove blower door. Find where thermostat wires come into the control board and remove them. If you can find a jumper wire or aligator clips, hook them between R and G. Put blower
door back on and turn on power,
Fan should come on right away, if it does you might have a thermostat problem. If nothing happens but you can hear it hum
or hear nothing at all. Then more than likely the capacitor is bad and or the motor is bad.
Aug 04, 2010 | Coleman Heating & Cooling
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Groaning Noise While AC is on
this sounds like the AC compressor is failing, the engine idles slower in drive so noise is more apparent. you are likely going to need to replace it soon.
Jul 23, 2009 | 2007 Suzuki Forenza Sedan
HP Pavilion a1150y fans run when powered on but windows doesn't load, monitor, mouse and keyboard do not work. (Running Windows XP)
Believe it or not, it's due to a weak power supply. More specifically, weak voltage rail/s caused by failing Electrolytic Capacitors.
A bad computer power supply is about 70% of computer failure.
ALL the light use less than 1 Watt. EACH fan uses 2 to 3 Watts.
A processor uses 55 to 125 Watts. Depends on the make and model.
Since the power supply is weak, it doesn't have enough power to turn the processor on.
No processor, nothing to find the Boot record on the harddrive. Nothing to get the Operating System going. (Example: Windows XP)
No computer running, there is no signal to the monitor.
Just enough power to light lights, and spin fans.
Apr 13, 2009 | HP Computers & Internet
I have a 5 year old Dell Dimension 8300. Lately I have been having problems getting it to come on and stay on. Once running, it stays running great. Today it wont stay on. I hit the power and sometimes it...
It is likely your power supply is failing. When you press your power button a signal goes through the motherboard to the power supply, then the PS comes on. I would try a replacement power supply first, you can get a used one for less than $20.
Dec 31, 2008 | Computers & Internet
HP Pavillion dv9720us Notebook PC will not come on
i got mine fixed at r-tech for 160 dollars, they fixed my motherboard (818) 347-1100
Jun 25, 2008 | HP Pavilion dv9000z Notebook
Toshiba Satellite A135-S2266 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
