Question about Ariston Technologies Washing Machines
Machine not turn on even the board and eprom changed
    Top Expert:
  • Ariston Tech... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
Vizio GV42l turns on with remote.Not by the tv, but no picture or sound. And I have to turn it off by unplugging it. Because it will not turn off by the tv or remote.
your EPROM IC is down/bad.
try the shop to fix this. if your handy by locating this IC, what is an 8 pinned IC, change it by using the correct part.
be careful to buy the correct part because you will get an even worse picture if it is a wrong one. each EPROM is dedicated for the program to be run on a tv set. nevertheless you can also program a empty EPROM IC by yourself with the original remote but you will have to use a password to achieve this.
whish you succes and enjoy :)
Aug 23, 2010 | Televison & Video
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
When I turn my TV off it loses all the setup changes I made!!!
Defective eprom !!! You probably won't find it by itself. You'll will have to replace the Main board.
Oct 01, 2009 | Westinghouse PT-16H120S 16 in. LCD TV
Philips rear projection TV model 60P8342.
It`s not Eprompt, it`s the Eprom, Erasable Read Only Memory. The Eprom holds all the information in it about your set like has it got Ni-cam Sound, A wide-screen, A projection set plus a lot of other information like Convergence settings, RGB setup, PAL, NTSC settings plus customer settings like Colour, brightness etc. There are other settings besides these which are in binary bit code which can control the power supply, Standby timing etc etc. The Eprom may only be an eight or a sixteen pin device but it a crucial part of the set where information is perminantly being read from the Eprom to make sure the three guns are set correctly and the convergence errors are being kept in check. This is a very time consuming job even for a qualified technician, I know, I used to do these and Philips sets are notorious for Eprom and uPC failures. The Eprom comes formatted from the suppliers, so there`s absolutley no information in it at all meaning that you have to start from zero. If you can get the set to come on long enough and you can get the set into service mode, you may be lucky where you can write down the 200-300 or so settings, If not, WHAT A JOB. Believe me, you can change the Eprom in 2 minutes, but it could take 1 or 2 days to set it all up again and even then it`s very difficult to get it perfect. Ian
Aug 10, 2009 | Philips 60P8341 60" Rear Projection...
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
TV Help!!
Yes , this sounds like the EPROM IC is failing or the crystal that keeps the frequency on the IC needs to be replaced , or even the buttons on the tv could be warped by the heat of the tv( if it is the buttons , then removing the control board from the plastic buttons will stop the random cycle and may make it so you can turn on the tv , but if not then it is the EPROM IC or crystal)
to check and see if the chip is messing up , hold down the menu button on the tv or vol up down and see if it stops cycling thru the video inputs
electech
Nov 21, 2008 | Televison & Video
New board eeprom
eprom is available as a spare from hotpoint. however, there is a good chance that the old eprom is ok in my experience.
Aug 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Crazy TV?????
Hi, either the eprom is corrupted or the front control board is bad, the control board can be a diy job but not the eprom. Have you pulled the tv`s AC cord for 30 seconds and then plugged it back in to see if that will do a re-set on the micro ? If not try it, you`ll have to remove the back of the set and pull the cable from the control board while it`s on so if this makes you nervous call a tv tech instead of attempting it, be advised that removing it while the set is turned off will not work because of course there is no way then to turn on the set, hope this helps, questions? e-mail me back, BMW Rider
Dec 31, 2007 | RCA TruFlat 27F520T 27" TV
Washing Machines Logo
21 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
