Question about whipper snipper Garden
Replacing starter spring ryobi 30 cdnb line trimmer
5 Suggested Answers
SOURCE: Ryobi 105r replacement line
Look at the top of the spool. Line up the two triangles/arrows by turning the inner wheel The inner wheel is a little smaller that the diameter of the spool and has grip lines scored around it. Just below those arrows, on the side of the spool there is a hole where the line would come out of. Thread the line into that hole until it comes out through a hole on the top of the spool. Then bend the end of that line over and stick it in the little hole next to the hole it came through. That will lock it in place. Pull on the other end of the line to tighten it. Now turn that inner wheel and the line will wrap around on the inside of the spool. When it stops and you can't turn it anymore, it's full. Cut the line off about 10 inches or so outside of the spool.
Posted on May 19, 2008
#1 Taper
  • 1041 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
I have a ryobi hedge trimmer RHT 2660 DA why wont the pull cord wont return ?
If you can try and tap by the starter housing with a small hammer and then you need to get some lubricant spray injected in to the spring. If it wont go back in there is a chance the spring has either broke or become unseated.
Jul 28, 2014 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Ryobi line trimmer cord won't retract. We have been told needs new spring, no parts? what can we do
They sell starter springs for Ryobi recoil units right here on the internet. Why do you say...no parts? Are you in Austrailia? Go on this site and enter the model of the trimmer to observe the parts available for it. If you don't like the price, at least you'll have an idea of the part number and pricing too.
Feb 02, 2011 | Garden
I have a 26cc ryobi weed trimmer--primer bulb will not draw fuel, but will draw fuel when I loosen the 2 screws that hold down the bulb
Possible issues:
1. Primer bulb or bottom assembly has crack or hole in it (needs replacing). See ebay for about $6.00
2. Fuel lines are not sealing to the primer nipples properly (cut line and re-attach if you have sufficient line available) otherwise; replace.
3. You may be somehow kinking the fuel lines when you clip it back in place due to fuel lines too short
My bet: #1 or #2. Good luck!
Sep 17, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi 30cc string line trimmer model # 0304AB 2005 model. After cleaning the carborator and replacing the fuel line, I found two needle values that need to be readjusted . Which of the two...
A good starting point for the Hi and Low speed jets is about 1 and one/half turns OUT from a lightly seated (all the way turned in) position, Never overtighten these as the tips can be damaged. This setting should enable it to start and if one jet had a spring on it, the other one should have one also. Maybe state carburetor/model #'s in another post?
Aug 07, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryoby weedeater throttle housing. Replacing the throttle spring
From the limited information you have given I think your throttle wire is binding. It could just need lubricating or the throttle shaft or butterfly in the carburetor could be binding. Disconnect the throttle wire from the carburetor and see if the throttle wire is moving freely and check the throttle shaft in the carburetor to make sure it is moving freely. If both are free, then check to see if something is pinching or binding on the throttle cable.
Sep 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starter cord will not retract ryobi bc 30
The spring for the reteact has possibly come off. You will have to open it up and replace it or put it back on.
Jun 03, 2009 | Garden
Replacing the 3 fuel lines
check my postings 3 days ago it give a good run down
Dec 20, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top whipper snipper Garden Experts
John Mayer
John Mayer
Level 1 Expert
richie46
ray gallant
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
