Daikin R410a filter
Thermostat saiys to clean filter Unit is only blowing out cold air
diths_kri
  • 67 Answers
SOURCE: central heating HVAC blows cold air -
stat or low battery in tstat
Posted on Jan 07, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
  • 1632 Answers
SOURCE: why is my window unit just blowing warm air? the filter is clean,
Shut the lever to outside resiculation air.
Put the fan on slow,
Clean the filter and the temp probe in front of it
Vitally
Posted on Jun 02, 2009
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 30 Answers
SOURCE: panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Dalkin VRV system air conditioner not cooling
Most the time when unit does not get cold,but air is still attempting to blow air, it is because it needs to be cleaned. Sometimes filter or vents are dirty. Try and use a can of compressed air and blow it out real good, next step is check the thermostat to see if you hear a click sound when turning it to a certain temp. If not, it can be the switch it self or the relay that triggers it. If you can give me a few more details of what it is doing or not, maybe I can get down to the root. In other words, you say it does not get cool. But, does it blow air>? fans turning? fuses ok? right source of power to it (amps?) mike
Nov 29, 2011 | Cfm Daikin R410a Split System Air...
Lost manual for model R410A Daikin invertor. Where can i find a new one?
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
Nov 03, 2010 | Cfm Daikin R410a Split System Air...
Where is the filter located on a R-410A Split System Air Conditio
Hi!!
The filter is located on the outside unit, Near the compressor.
Don't forget to rate this post!!
Jul 17, 2010 | Cfm Daikin R410a Split System Air...
Three month old R410A Daikin a/c not cooling?
Hi; dont worry unit is still under some kind of a warranty, either from installer or manufacturer. Please find out before You or a friend try to fix. This can void Your warranty...
Jan 20, 2010 | Cfm Daikin R410a Split System Air...
Fan Coil Unit is Cycling on and off. But the room is still hot.
Check electrical connection at the T'stat and the indoor blower . Sounds like a loose connection.
Sep 11, 2009 | Cfm Daikin R410a Split System Air...
NO cold air
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Therefore I would request to add r410a refrigerant for better cooling. Thanks for contacting Fixya.
Jul 05, 2009 | Cfm Daikin R410a Split System Air...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
