Upper (gray) fuser roller needs replacing, (tear on 1 side).
I have a Canon PC-6RE Copier, yes, its old and its like a old friend, yes, yes, its old and discontinued, so what, its still works and still copies. the copier is making a vertical line and its the upper fuser roller, i can see it, it has a tear on 1 side, and that was caused by using the copier when the toner cartriage has gone dry and that long cotton brush that goes on top of the upper fuser roller was very dirty. Now, is that upper fuser roller easy to replace? I can use some help, i am a good self starter, i can get the part, just need some help. thx u.
  • Alberto Stevenson Jan 04, 2009
    To: archman50
    Re: Canon PC-6RE. Replacing upper fuser roller.
    Dear archman50,
    Thx u for your instruction. I just need some more detailed instruction from u. Where do i start to get to the upper fuser roller 1st? Taking of the outer plastic cover? And where do i find some Silicone fuser oil and cleaning pad? Thx u.
    ars7777
  • Alberto Stevenson Jan 06, 2009
    Re: Posted Comment on Jan. 4, 2009 (Canon PC-6RE Copier).
    ATT: Archman50
    Hello Again Archman50,
    Need another Answer or Instruction from you. Question, is Fuser Oil also called Oil Wick? And is that pad or Cleaning pad on that long black rod with a handle and sits above the upper fuser roller is the Cleaning pad? Please let me know, I found a upper fuser roller or $12.00, Please let me know. Help me, thx u.
    ars7777
    Novelist:
  • 148 Answers
If you are handy it is not hard to replace the upper fuser roller you will need a small phillips screwdriver and pliars
the fuser lamp goes through the fuser roler so youmust disconnect the power leads to the lamp and remove the lamp
You do have to release the back side of the drive
gear on the fuser roller
when you install the new roller be sure to put some silicone fuser oil on the cleaning pad
take your time good luck
Posted on Jan 04, 2009
  • Steve Archer Jan 04, 2009
    to remo, ve the fuser roller open all doors and if copier is **** shell design open up like you clear a jam
    remove plastic back, plastic area where seperation fingers are located, remove pad and anything that holds the fuser roller
    down on top of other roller
    there is a company called katun corp out of canada that supplies fuser rollers and they supply wholesale I am not sure you can purchase from them direct contact the local canon dealer or a copier repair firm and et a price from them for fuser roller and oil( fuser oil is basicly silicone oil hgh temp
    make a diagram of the fuser assembly before you remove so you can reassemble do not put your fingers on the glas heater lamps the oil from your hands will cause it to get real hot and burn out
    handle fuser lamps by the ends(ceramic tips
    good luck
Fuser upper roller problem
Apparently you just need the pressure roller, if noisy, you can change the bearing.
Good luck ...
Apr 24, 2012 | Canon imageRUNNER 8500 Copier
I have the e005 code, where are the upper and lower fuser roller located in a ir 400s?
A E005 error code means that the cleaning web needs to be replaced & the web counter needs to be rest. The fuser unit is on the left side of the copier, the side that the paper comes out... Good Luck
Jan 22, 2011 | Canon imageRUNNER 400S Copier
Canon PC 940. replaced a $6.00 roller because bushing broke. Now I get code "EO". any ideas
the heat element is not heating up check the connections at either end of upper fuser roller. unpluging copier for 20 minites should reset the error
Aug 19, 2010 | Canon PC-940 Black and White Copier
there really is no need to remove the cleaning web when replaceing the upper fixing roller.... it stays in place and will not present a problem apon replacement
Jun 04, 2010 | Canon imageRUNNER 5000 Copier
I have a Canon NP 6230 copier and I have long black mark all the way down the left side of the paper. It looks like it could be a roller or something. Where should I look and what should I do
it could be 1 0f 3 things ! 1. could be dirt on the optics mirrors 2. could be scratched or worn upper fuser roller 3. could be a worn or sratched drum or drum charge roller
Apr 17, 2010 | Canon NP 6230 Copier
I need a user guide for an old Canon copier model PC-6RE
You'll have difficulty finding that one, but really..... what is there you need to know?...it's as basic a machine as there ever was.
Apr 25, 2009 | Office Equipment & Supplies
Old canon copier prints thick balck line down right side of paper
tthis is really old 25 years plus. replaced the drun cartridge which also contains the toner good luck canon sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
How do I change the roller in the fuser?
im assuming your talking about the upper roller in the fuser? if so you need to take the unit out 2 silver screws on top looking back at you. and replace the unit try ebay. those rollers are very difficult to do
Dec 23, 2008 | Canon imageRUNNER C3220 Color Copier
Canon pc-6re
hi do this to reset the fuser unit:
go to service level one by pressing  *28* then copier --function--clear--error-ok
if that doesnot work either replace  thermistor
Best regards
Aug 04, 2008 | Canon IMAGERUNNER 6570 Copier
Canon d760
there are 2 possabilities for this
1 the drum unit is worn
2 the upper fuser roller/film has worn out
a visual check is needed to determine the cause
please get back to me if you require further assistance
Thank You
Jun 20, 2008 | Canon imageCLASS D761 Copier
703 people viewed this question
k24674
jasbo
jasbo
