Question about Verbatim Computers & Internet
My external keeps making beeping noise
My computer, playstation3 can't read my external hard drive and i got a lot of memory on there, and i no longer have the receipt and i paid cash for this couple of years ago
  • Verbatim Master
  • 27,725 Answers
To attempt recovery put it an an open external enclosure and have another one hooked up to recover the data to.
Gently tap the hard drive with an open hand and see if you can get it to spin up one last time.
Of course it can be sent to a data recovey company if you really have to get the data off.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
There are no user serviceable parts inside the drive.
Opening it will just negate any chance of recovery.
You're not going to fix it by disassembling the drive.
The click's and beeps indicate the drive it damaged; there is a good chance (98%) that you have lost all of your data.
Note: By removing the cover from this drive the any remaining warranty will be void and all data will be considered lost.
Now if you still want to take it apart just to look inside, there will be one or two screws that are under the manufacturer's label that will have to be removed.
Pressing firmly, run you finger across the top of the drive until you can feel the depression where the screw head is.
Using you screw driver puncture the label and remove the screw.
Then you can pry the top cover off.
hope this helps
Posted on Nov 03, 2012
Benimur
  • 6966 Answers
SOURCE: Maxtor External 500 GB Hard Drive
Hi, 1. "Is the data recoverable?" Yes but the manner by which it can be recovered can be either very expensive (their are firms whose specialty id data recovery) or none at all if you do DIY (do it yourself) or worst case not economical reasonable but recovery possible. I would assume that your would want to try DIY. 1.1 Run diagnostic on the external drive using scandisk, Norton Disk Doctor, Partition Magic's ChkDsk and/or Check Errors. Recovery can be done using a recovery software such as GetDataBack; or 1.2 You need an external desktop PC, a working knowledge of computer hardware. You have to disassemble the external HD and remove the actual HD. Physicall connect it to the 2nd PC (desktop) as a seconday Master either by IDE or SATA as applicable. If detected by the desktop PC in the bios, you should be able to work on it even if with errors; 1.3 If mechanical problem or otherwise, you may want to check out this posting > http://www.fixya.com/support/t162904-seagate_barracuda_7200_7_st380011a Hope this works out for you and/or give you some ideas. Pls post again how things turn up. Good luck and kind regards.
Posted on Aug 05, 2007
SOURCE: External Hard Drive No Longer Recognized
hey im the same person who just posted above. i went to WD's website, and it said unplug the hard drive from the computer, and unplug it from the power source. then plug it into the power outlet, wait for it to spin up, then plug it in via USB/Firewire, whatever. it worked for me, so hopefully it will work for you.
Posted on May 13, 2008
DickCanFixIt
  • 948 Answers
SOURCE: Hitachi External Hard Drive (500GB) Beeping sound
Probably not. You can try putting it in the freezer overnight (in a bag please, don't get moisture in it) but most likely if you must have the files back it will take professional help.
Posted on Jan 30, 2009
Crankstart
  • 696 Answers
SOURCE: What does it mean when my 1TB Iomega external
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist. In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 08, 2009
bhagyavichar
  • 414 Answers
SOURCE: maxtor external hard drive fell on floor (maybe a
yeakis..!!..
itz probably not normal anymore..it do happen while boot up or when hdd gets power..hdd consists of one or more solid n heavy platter(s) like gramophone media/disk in miniature, which is spinning at more than 7200+ rpm just on a single pivot which is thick just around a dot pen's nib..there is one lens each on both side of the platter of abt 1mm probably..and the whole assembly do function somewhat alike gramophone....
nw u cn understand how highly balanced they r..due to time, illegal shut down, moving/shacking/thud/shock to the hdd while in activity, may cause damage to it..and the first n common symptom is either no activity or 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..!!
do claim warranty..report as hdd dead..don't tell itz physically damaged..
try contacting ur system admin/vendor without delay....
Posted on Nov 16, 2009
1.finding top quality external hard drive with extremely user friendly software when there are so many to choose from--which one? pc is making wierd grinding noises from the right side of the keyboard
This weird noise is a symptom of physical hard drive failure. So, if you really want to save your data immediately consult a data recovery specialist.
Feb 25, 2013 | Computers & Internet
My external hard drive always makes beeping noise
You may have to have the data recovered from the drive.
Nov 01, 2012 | Verbatim Computers & Internet
The Hard Drive keeps making a bleeping noise and it is not letting me acces it, what could the possible problem be?
you need to know computer BIOS to know message from beeping code. when u know the BIOS product then listen the beep (short or long, how many beep, etc). after u recognize the beep pattern, try to 'google' it with your BIOS product and beep status. or u can reply from this answer, maybe i can help.
tips: a lot of problem that computer cannot run and makes beep sound is that RAM not correctly installed, try remove it and put it in again in another RAM slot. if u use external VGA, try to remove it and put it in again.
hope this useful, regards.
Aug 16, 2011 | Computers & Internet
Iomega eGo was working before and not now. All it does is beep. Read on other forums that it could be a power issue. Windows sees the drive in device manager but drive doesn't spin up. Just beeps for...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 15, 2011 | Iomega eGo 1 TB USB 20 Hard Drive
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My hitachi external hard drive can't be found by my laptop
Remove it and install it into another computer to see what'll happen.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it,you can recover data on it with data recovery program to avoid losing them.
I have succeed with Tenorshare data recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash and 'not recognized' issue.You can get it here: http://www.any-data-recovery.com/index.htm
After you recover your data,you can format it to check out whether it can be fixed.
If the hard drive can't be detected,you can try this way.Put it in a zip-lock bag and put it in the freezer overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office but let's hope not because it will cost you a lot of money and whether they can recover data is not guaranteed.
This article will help.
How To Recover Lost Data From Crashed Hard Drive?
http://tenorsharedatarecovery.blogspot.com/how-to-recover-lost-data-from-crashed.html
Feb 13, 2011 | Hitachi 500GB External USB 2.0 Hard Drive
My external hard drive continuously beeps and makes a clicking noise. Also, no computer is able to recognize this external hard drive.
The spinning mechanism on the HDD is failing meaning it can't read data of the platans. Unfortunately you need to buy a new one as this one can't be repaired.
Dec 29, 2010 | Hitachi Computers & Internet
My WD external hard drive does not stay recognized on my computer. When I first plug it in it makes the ding/beep noise and shows up on "my computer" but after a few seconds it makes the ding/beep noise...
Try the hard drive on another computer to see if it is the external or a laptop interface problem. There are EIDE/SATA to usb adapters that you can connect a hard drive to that the computer will then read as an external hard drive. The problem with external HDDs is the usb interface built into them, these are mounted on controller cards and that is ususally where the failure occurs.
Jan 10, 2010 | Western Digital Passport 320GB External...
Hi there, seem to have lost my external harddrive on my desk top, and it is making a beeping sound??
Hard drives don't beep. They make a lot of sounds, but no beeps. If the drive is actually making an unusual noise, it has probably gone bad. Clicking would be a bad disk. Any other noise would be a bad controller board. A good shop may be able to slave your drive to another computer to try and save your data. But don't count on it. By the time a drive makes a loud noise, it's usually gone and unrecoverable.
Before spending a lot of money to recover your data, try the external drive on another computer. Maybe the connection USB port has gone bad on the original computer.
Nov 12, 2009 | Maxtor Hard Drive
Computers & Internet Logo
418 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
