I cannot print collated copies on my Toshiba Tec B-SX4
5 Suggested Answers
SOURCE: unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
  • 20 Answers
SOURCE: HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Posted on Jul 07, 2009
  • 254 Answers
SOURCE: Hi, I can print to a TEC B-SX4 from a windows 2000
this is due to continuous polling by the driver.
You must disable the bidirectional communication in the tools tag ,driver options, network parameters.
Posted on Sep 02, 2009
  • 254 Answers
SOURCE: Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
Posted on Aug 05, 2011
How to change from Thermal Transfer to Thermal Direct on Toshiba TEC-SX4
Hi Ryan, refer to sections 5.2 Overview and 5.3.1 Printing Mode Selection from the following pdf manual. Hope this helps.
http://www.cmsitechnologies.com/TEC%20Drivers/BSX45TUM.pdf
May 20, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
How do I turn the rotary cutter on and off our toshiba SX4 thermal printer running windows
You can juste select the option in teh windows driver.
Select batch printing and no cutter when you don't want to cut.
Nov 18, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Tec sx4 network
Have you checked the port Number.
Tec use port number 8000 and the standard default in windows 9100. Either you change on your printer or in the driver.
Feb 12, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Smartforms printing to TEC B-SX4 in SAP
this may be because the instructions are truncated.
Check by using the dump function on the machine
Dec 07, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I have a TEC SX4 printer which im trying to
There is usually a setting in your label software or printer driver that lets you choose between thermal transfer printing or direct thermal printing. Make sure your setting is on direct thermal.
Hope that helps !
Aug 12, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
I have a TEC SX4 printer and im trying to convert the machine to print on thermal labels without a ribbon.. I don't know how to do it! Can anyone help me please
Quite simple.
- Remove the ribbon
- in the support tab of the driver select direct thermal.
- Send a test print to the printer.
It's done
Aug 11, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Hi, I can print to a TEC B-SX4 from a windows 2000 print server, but if I set the printer up on a windows 2003 server it goes offline and refuses to print. Same drivers Seagull 7.1.1.
May 11, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
23 people viewed this question
k24674
jasbo
jasbo
