Question about HP Office Equipment & Supplies
HP Officejet Pro 8500 A909g Series is printing photos red
All my photos have a red tint when printed on the HP printer. My ink cartridges are not low. Why are my photos red instead of true color of picture?
tipstir
  • 67 Answers
SOURCE: hp officejet pro l7780
Run the cleaning tool before you print a test page.
Posted on Aug 02, 2008
  • 5472 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
  • 53 Answers
SOURCE: Installed a new HP black ink cartridge; the
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
Posted on May 12, 2010
Testimonial: "I performed all of the diagnostic tests. Ther black ink still does not appear on any copies. I should say it is a very faint grey and it fades to nothing when printing a full page letter. I need to find whether the ink flow from the cartgridge to the print head is clogged and how to flush it. The printer is less than 6 months old, but was not used for over 2 months."
dj_relly999
  • 4070 Answers
SOURCE: HP Officejet Pro 8500 wireless- Is there a print
Hi! Please try to unplug the unit from power source and press/hold the power button while unplugged to reset the system. This can be just a system failure which needs to be resetted. After 10secs. plug the printer, turn it on and observe how it goes. Hope this helps and thank you for using Fixya!
Posted on Oct 09, 2010
vonnielsen
  • 169 Answers
SOURCE: in hp officejet pro k5400
Try Cleaning the Cartridges manually and automatically.
For the cartridge clean it with a damp lint free cloth and also for the printheads wher eyour gonna be inserting the cartridges.
Follow these steps do do the automatic aligning and cleaning:
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Go to Printing Preferences 3. Click the Features Tab 4. At the bottom of the window you will see Printer Services or Device Services. Click on it. 5. Choose Align Printheads on the list.
For Cleaning the Printheads, Instead of choosing Align Printer choose Clean Printheads.
I hope this helped.
Try Printing Again. I hope I was able to solve your problem. :)
Posted on Feb 08, 2011
Ink leaking in HP 8500 A909G printer
for this you have to strip the printer. your wast tank is full. you can take it out and clean it whit worm water. hope this will help
Sep 07, 2012 | HP Officejet Pro 8500 A909g Wireless...
I have my HP Officejet 8500 connected by cable it starts printing then stops for a while then completes. can you help?
These units have two areas for ink, the normal cartridges and what they call print heads.
As you print ink is sent to the print heads, the pause is more than likely this operation.
Depending on how long you have had the printer the print heads may need to be replaced, however the printer will tell you if they need to be changed.
Hope this helps!
Apr 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an HP Officejet Pro 8500 all in one printer. My magenta doesn't print. I can't print anything with red/pink in it. Can you help?
Try another cartridge first, making sure it is located properly in its seating and is the right spec.
You may not know, 8500 non wireless cartrigdes do not work in wireless A909.
Are you talking about replacing the cartridge at the left side front cartridge compartment or the printer heads under the scanner lid?
Feb 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My HP 6500 709N all in one printer displays "paper jam" error message. Have searched thru printer - no jam, no little bits of paper. Have been thru the trouble shooting process - doesn't help and...
HP Officejet Pro 8500 (A909a) All-in-One Printer This model has a two-line display.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
HP Officejet Pro 8500 Premier (A909n) and 8500 Wireless (A909g) All-in-One Printers These models have a touch-screen display.
  1. Touch the Setup icon.
  2. Scroll to and touch Tools .
  3. Scroll to and touch Restore Factory Defaults . A Defaults Restored message displays.
  4. Press the Cancel button to return to the main menu.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Black ink cartridge is full, but it does not print
It is more likely that you have a bad or damaged Smart Chip on your Black ink cartridge. Check out this site, it may be helpful adaptiveink.com
Jul 27, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Ink smears on photo prints- in never dries. This is a new problem,
HP ink is water soluble. It comes off or smears onto a damp finger. So now I have an issue with HP.
216 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
