Question about Samsung Televison & Video
Need a lcd tv pedestal stand for samsung la46a950
SOURCE: how to get pedestal off a toshiba 32 HL 67
Take out 5 HEX head screws and one black screw from jack pack cover. the pedestal will slide out from bottom. You do not need to remove jack pack cover as it is part of entire back panel.
Posted on May 22, 2008
ron1235
  • 11 Answers
SOURCE: Need a pedestal stand for an AKAI 42" Plasma
do you have the small feet as shown in the picture? are they in your closet?
ebay?
Posted on Nov 30, 2008
SOURCE: Where can we find a TV pedestal stand
You will have to send them an email on there website here's a link to the contact us page
CLICK HERE
Tell them you need to buy a replacement stand and give them the model number of the TV. They will reply with an amount and payment methods. Ive done this before for replacement remotes and monitor stands. Good luck and have a good day, Dantechcom.
Posted on Jan 05, 2009
  • 8 Answers
SOURCE: Can you provide parts list
This is the link to parts for your model tv. I hope it helps! :)
http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=LN32A330J1D&modelid=512510
Posted on Feb 05, 2009
javswr
  • 44 Answers
SOURCE: TV wobbles on its pedestal stand.
Sounds like stand has been installed wrong an maybe miss aligned, and screws may be loose! Try removing and start over, or call installer back.
Posted on Feb 28, 2009
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
Need a stand
I could not locate a stand for purchase on http://www.partstore.com/Model/Samsung/Samsung/PDP4294LV1.aspx
By the way, your tv is a rebranded Samsung model.
Without the stand, you only option would be to wall mount the tv.
You can purchase a wall mount for your tv from your local Wal-Mart or something to that effect for around $30.
Mar 13, 2011 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Tv stand
you should try Ikea...they have everything :D
Aug 16, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
Can you provide parts list (part #'s) for ln32a330 lcd tv pedestal stand? My assembly manual indicates that there is the stand, a plastic ring, a guide stand, 3 (a) screws and 4 (b) screws. Any others? I...
Dec 17, 2008 | Samsung LN32A330 32 in. LCD TV
Televison & Video Logo
Henry  Thomas
Henry Thomas
