Question about Everex StepNote XT5000T Notebook
Hp laptop random shutdown - overheat?
My HP pavilion started shutting itself down -- first the screen goes black and then the computer shuts down. At first it was just sleeping or hibernating but the longer it went on, it would shut down. Also the intervals of functioning got shorter. Also, it says the AMD Turion 64 x2 TL50 drivers are corrupt or missing. How can the computer run with the processor drivers corrupt? Installed speedfan and it is hot. Won't measure the fan speeds.
  • Anonymous Jan 12, 2009
    I am the original poster. Ended up taking it to geek squad (the second store was very helpful, the first was not). Turns out the hard drive was bad. They couldn't find anything else wrong with it after complete diagnostics. We will see.
  • Anonymous Jan 28, 2009
    help
    Sniper:
  • 87 Answers
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Posted on Jan 12, 2009
    New Friend:
My hp 430 notebook pc shut down automatically after I use it for some times.. It says "Thermal shutdown...
Posted on Nov 27, 2012
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Hp pavilion ze1115 stuck on hibernating..
Open Control Panel, Power, power settings, change power settings to high performance, Disable Hibernation, sleep. When your laptop is not in use shut it down and unplug. It will last longer and a boot everyday will reset the laptop.
Dec 17, 2012 | HP Pavilion ze1115 Notebook
Dv9740 hp laptoop does not shut down or sleep
Open power settings adjust. OR shut down at the start up menu. You can always push the on/off button. When not it use shut your computer down, unplug.
Dec 15, 2012 | HP Pavilion DV9740US Laptop
Have a new HP Pavilion entertainment pc with Windows 7.
I also have a HP Pavillion dv9260 , had the same problem, HP help live said the video board, which is an intergral part of the mother board is bad....burnt out...needed to replace the motherboard and they won't stand behind them...I was out of luck $400.00 to repair and stories are that it won't last long even if you do...so here it sit's basically $2400.00 dollars worth of scrap parts........
Dec 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Screen is black. Hear computer trying to boot up.
cpu fan failure try to put a big fan where the comp vents and air flows! and see if its not shutting down!
Jul 01, 2009 | HP Pavilion dv5-1000us Notebook PC
LAPTOP WILL NOT COME OUT OF 'SLEEP' MODE
Turn it on, then wait, u will hear the computer turning itself on and off, but nothing is showing on the screen. so make it turn on and off, 3 time.( such as hearing the computer turned off, so that one,THEN IT TURNS ITSELF ON AGAIN, next time it turns off, that count as 2, and so on). on the third shut off then u press and hold the off button, to force it to shut down, then wait. about 5-10min., or less then 5. after then u turn the computer on.it should be on by now. if not try it again. if it happens again try one more time, if it happens again. then there something really wrong with your computer.
Jun 15, 2009 | Nikon COOLPIX L20 Digital Camera
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
Everex StepNote XT5000T Notebook Logo
1,744 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
