How to fix samsung washing machine model TORNADO 7.0kg WA90B error
Samsung TOUNADO 7.0kg WA90B error E1 problem
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
Posted on Nov 01, 2012
SOURCE: hi am getting e1 error in my washing machine
what is an E1 error message
Posted on Jan 04, 2010
SOURCE: E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Posted on Jun 23, 2008
SOURCE: Can't get rid of E1 error on a Samsung front loader washing mach.
E1 : washing machine has exceeded a check time for fill, heat or empty.
Common causes for this are fill and empty problems, heater fault (or the wiring
to it broken), water pump open circuit (although that would stop the water draining too) Pressure chamber blocked or pressure tubing pipe looped below the pressure bottle, or a sticking eco ball in the sump hose (sludge and grease build up)
This error code is generic and vey common.Since you have tried the remedies.Try getting checked the internal wiring damage by professionals.I hope certainly hope the problem lies there.
Posted on Dec 10, 2008
  • 1738 Answers
SOURCE: error e1. washing machine will not drain
Two problems. Step one check the drain pump motor, to see if it draining the water out. Next step if the drain pump working you have a clock in the hose between the drain from the tub to the pump. Messy job witht he machine being full of water. I suggest take a small bucket and empty try to empty it out as much as you can.
Posted on Aug 10, 2009
blueextc3221
  • 15935 Answers
SOURCE: E8 error code
8E - OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    My samsung automatic washing machine wa7584c1 is giving me a 1E error why
    You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
    CERACOAT-NANOTECH.com
    May 14, 2015 | Samsung Washing Machines
    Washing machine E1
    You have not included the make and model of your washer so that makes it pretty hard to answer for sure. A google search shows that several makes have an error code of E1 and it refers to a slow drain. Attached youtube video link is for a whirlpool washing machine and might help. If not repost with the make and model of your washer.
    Washer Repair Drain Pump Error F9E1 Maytag 2000 Series Whirlpool Duet...
    Aug 16, 2014 | Washing Machines
    Samsung washing machine error E1
    This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
    Nov 04, 2012 | Samsung SW62ASP Top Load Washer
    Error E1 samsung washing machine model TORNADO 7.0KG WA90B
    -Display Shows 'E1'
    Keep me posted!
    Nov 01, 2012 | Washing Machines
    Dec 09, 2008 | Washing Machines
    Mar 21, 2008 | Samsung WF337AA Front Load Washer
    Washing Machines Logo
    187 people viewed this question
    Top Washing Machines Experts
