Question about Refrigerators
The door ajar alarm displays on my new Nutid Ikea refrigerator and wont go off. because of this the water dispenser won't work because it thinks the freezer drawer is open
I've tried to reset it by unplugging it but the door ajar icon still displays
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check to see if the door switch is working and that no wires have come off.
Posted on Nov 01, 2012
HVACRH20
  • 237 Answers
SOURCE: Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Posted on Nov 09, 2006
SOURCE: water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Posted on Nov 12, 2008
  • 115 Answers
SOURCE: door ajar alarm ringing and refridgerator not cooling enough
it sounds like either a defrost problem or damper door problem it is very well worth fixxing
Posted on Dec 28, 2008
Maytag317
  • 1136 Answers
SOURCE: We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
Posted on May 23, 2009
  • 9 Answers
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
Posted on Jun 23, 2009
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 03, 2015 | Refrigerators
Refridgerator beeps
Apr 19, 2015 | Refrigerators
How do you get the model 370lb to stopping beeping
Mar 30, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Door ajar warning light/interior light won't come on
Good Afternoon bibliophilel, based on the symptoms you are describing, may I suggest resetting the refrigerator. This can be done by either unplugging it or flipping the household circuit breaker off. Wait roughly ten minutes and then turn the unit back on. If the issue persists, then more than likely the light socket and/or the door switch that triggers the bulb and alarm are faulty. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance and repair.
Jul 19, 2013 | Frigidaire Refrigerators
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
