Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
The volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower
I turn on my ViewSonic N3751w and the volume lowers itself all the way down to 0 and the zero continues to flash like it is still attempting to lower. I have tried removing the batteries from my remote, and using the buttons on top of my television. I've tried unplugging the TV and waiting to plug it back in, but that doesn't work either. How do I reset this thing or get it to work properly? I can view the channel playing, but none of the other buttons on my television seem to be responsive... HELP!
  • 127 Answers
You can't reset it you have a sound problem circuit that needs to be fixed by a qualified tach.
Posted on Nov 01, 2012
5 Suggested Answers
  • 286 Answers
SOURCE: ViewSonic N2750w 27 in Volume turns down by itself
Could be a problem with the down volume button on the tv. the board it's on ir its harness. Check them all. Make sure the volume buttons plastic actuator moves freely and is not stuck.
If these parts are all good, you have a problem on the main board. You may have to trace the control lines as far as you can and check any capacitors along the way. If you have an oscilliscope you can test the lines to see if the up volume is working correctly. If there is noise on it, you might find a bad capacitor if you can trace it back far enough. Schematic helps here.
Of course, make sure nothing is shining on the sensor window on the TV. You might want to scope that line as well (IR sensor line).
If none of that helps, get hold of Viewsonic and find your closest service provider. You can order a main board from them.
Of course, you could try just using the audio out jacks to an amplifier or a surround sound amplifer. Then you would use the remotecontrol for the surround sound system to control your volume.
Bet you were going to buy one anyway right?
Posted on Feb 14, 2008
SOURCE: ViewSonic N4251w 42 in. LCD Television
pulled main board and reseat conector in the board right in the middle of the set. set is runing for two hours, keep you posted.
Posted on Nov 29, 2008
SOURCE: viewsonic n3251w will no longer display Closed Captions
You can reset your viewsonic remote control by removing the batteries, and holding the power button down for 10 seconds. Just 10 minutes ago I repaired my remote, which was doing absolutely nothing, not even turning the set off and on, Called Viewsonic, they told me this, and it worked ! Yay !
Posted on Apr 28, 2009
SOURCE: Powerlock Enable cannot be removed from my ViewSonic N3246w.
I have a 19" ViewSonic and if you hold down the 2nd and 3rd buttons together under the screen, counting from the LEFT, it will disable the Powerlock.
Posted on Jan 01, 2010
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
My viewsonic N3751w 37 in, tv will not power on
Is the status LED light on at all, if so what color is showing? if the LED doesn't even't light up, then the power supply is gone. Also, have you try using another power cable?
Dec 03, 2013 | ViewSonic N3751W 37 in. LCD Television
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
Need schamatics for viewsonic n3751w
There is no service manual available for a Viewsonic. You must trouble shoot it from knowledge. If you need assistance after voltage checks then feel free to re-post.
Apr 22, 2010 | ViewSonic N3751W 37 in. LCD Television
Volume spontaneously lowered ans stuck at 0
turn off manually and turn on it should work better than before
Jul 26, 2009 | LG 32LB9D TV
My Viewsonic N3751W 37-Inch LCD HDTV always shows 480p
your dvd is set to 480p. if it is a convertable dvd player set it to 1080i. the tv sets itsef to whatever the dvd player displays. if not all dvd is 480 to 720 p. blu ray will get you top notch 1080 display.
Jul 07, 2009 | ViewSonic N3752w 37 in. LCD TV
Picture too large for 37" ViewSonic screen
Try pressing the auto button.
If you can't find one try the + button or
right arrow button, then each other button in turn, one should reset to automatic settings.
If the onscreen display (OSD) comes up see if you can find an auto option by pressing the + or right arrow key
Jan 30, 2009 | ViewSonic N3751W 37 in. LCD Television
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
181 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
