Question about Xerox Computers & Internet
Copy problems with xerox fx docuprint c3290
When photocopying it misses a line in the middle of the page. It works fine when you copy from the computer and when you receive faxes only seems to be when photocopying.
    Problem Solver:
  • 14 Answers
Hi you can have a few problems. 1: try cleaning the glass on the scanner. 2. If you have auto document feeder there may be paper or dirt on the lens that the paper passes over. Clean the long lens. 3 if you clean the glass and lens and still have the problem you will most likely need to have it serviced as there may be paper stuck in the drums that the paper passes through. Paper follows a different path when copied versus a straight print. Try to see what path the copy paper is taking and clean it as best as possible. Last trick is to take out toner cartridges and wipe them clean. Shake them forward to back and reinsert. You may have a worn out roller and if this is the case it is usually cheaper to just buy a new printer.
Posted on Nov 02, 2012
Scanning to mac
Open System Preferences and make sure your scanner is in your computer under Print and Scan.
Then open up Image Capture and click on your scanner. Then click the scan button, which I have circled in red in the image below.
Mar 02, 2013 | Xerox FX DocuPrint C3290 FS Scanner
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
Ive got a xerox docuprint C3290FS that keeps comong up with this scanner sensor error 062-360, is there any way to fix it besides replacing the upper section of the machine? Thnaks.
Ive got a xerox docuprint c3290fs and everytime we fax it comes up with error 035-701 and it takes a couple of goes then it eventually goes through is there any way we can fix this problem?
Oct 13, 2010 | Xerox DocuPrint C3290 Printer
How do I set my Xerox Docuprint 3290FS colour printer to work without colour cartrige
unfortunately this cannot be done - best you can do is source a replacement chip for the
cartridge - worst, replace the cartridge with either a compatible or genuine one
Aug 13, 2010 | Xerox DocuPrint C3290 Printer
Need to reset c3290 to factory defaults as admin user/pwd unknown
Go to the Xerox.com website and follow the assistance links.
Good luck.
May 21, 2010 | Xerox DocuPrint C3290 Printer
Windows 7 does not have drivers for Xerox Docuprint P8ex
Hi all, The Xerox DocuPrint P8ex understands PrinterControlLanguage of version 5e or 6 (PCL 5e or PCL 6). So actually you can use driver from every printer supports PCL 6. Driver for "Fuji Xerox AP-II C2200 PCL 6" working very well for me on Windows 7 64bit. Steps to install: From Device Manager -> Other devices ->Right click on DocuPrint P8ex -> Update Driver Software -> Browse my computer for driver software -> Let me pick from a list of device drivers on my computer -> Double click Printers -> Fuji Xerox from Manufacturer -> FX AP-II C2200 PCL -> Next
Feb 12, 2010 | Compaq Xerox DocuPrint P8ex Laser Printer
Xerox Docuprint 3290FS colour multifunction black overtoning badly then spilling during "calibration", leaving very dark background and blotches of toner cyan overtoning mildly during "calibration",...
Xerox does not list that model at all - are you sure the model number is correct ?
It would appear that either the cartridge or fuser may be defective.
Does the machine show any error codes at all ?
Here is a user manual for a similar model 3225 that may help under the troubleshooting section :
http://www.office.xerox.com/userdoc/N3225/pdfs/UserGuide.pdf
This is where you find manuals for all Xerox products :
http://www.support.xerox.com/go/prodselect.asp?Xlang=en_CA
Oct 28, 2009 | Xerox DocuPrint C3290 Printer
Driver for windows vista
If found that if installed the printer as a Xerox DocuPrint 4517 instead of a Xerox DocuPrint N17b then the printer works fine under Vista.
The only thing that lead me to try this was that I found that N17b and 4517 used the same printer cartridges, so I guessed they might be similar under the hood too.
Nov 21, 2007 | Xerox DocuPrint N17 Laser Printer
Computers & Internet Logo
91 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
