What is e4 indication
Pls send more deatails of E4 indication and motor is not running
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Nov 01, 2012
4 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: the washeer machine give a error code E4
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
Good Luck And Please Rate FixYa!
Posted on Dec 19, 2008
Macmarkus
  • 2605 Answers
SOURCE: I have a e4 problem. But I can not get the door
Hi John, welcome to fixya. This error code you're receiving indicatrs a problem with the door lock has been detected by the control. Whether there IS a problem or not remains to be seen, sometimes unplugging the unit for a minimum of three minutes will reset the control, but I'd suggest manually unlocking it first and then reset it with the door open. The emergency latch release is behind the small round panel below the main tub door. **Unplug the washer or turn off the breaker before attempting any suggestion given here please** To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Be very careful as the edges are very sharp. A string will be threaded through the pump housing and you just need to pull it to open the main door. Let me know how you make out and also if you require further assistance with this problem. If you don't require further assistance and this indeed was helpful to you, please allow a moment to rate this solution I've given accordingly. Thank you for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 25, 2010
Macmarkus
  • 2605 Answers
SOURCE: Error message: E4....What means? I can't open the
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more with some luck. The E4 error indicates a door kock error, however the door typically locks as a result of the unit failing to drain, so....
1. **Unplug the washer from the wall or turn off the breaker before attempting any repairs**
2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)try a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open, unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets". Good luck !
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. (Sorry about the post, I'm still adapting to this "htc" windows 7 phone after having an iphone for 2years...very tricky lol )
Thank you for choosing to "FixYa".
Regards,
Macmarkus :)
Posted on Jul 16, 2011
How i solve error code e4?
see the MANUAL of the fridge and then operate
Jun 10, 2014 | Refrigerators
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
It wont start at any level
E4 indication? Like a error message? About what are talking here? Send us details
Aug 09, 2012 | Cars & Trucks
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
I have a Sears Pro Form 730si. The treadmill
I believe E4 on ths 730si means that the speed of the motor the sensor is detecting is greater than the set speed. E2 would be the opposite. I believe there is a way to calibrate the speed. Look at the smaller motor controller board.
Jul 14, 2009 | Exercise & Fitness
Error code 4
check the sub code , it would read E4-? , such as E4-10 is fuser fan, E4-01 is low fuser temp, sometimes hold the print key after in code and sub code may appear. Then you can go to next step of repair.
Jan 30, 2008 | Panasonic FP-7735 Black and White Copier
Unit shuts down
The E4 error in display its mean the wire sensor connector to thermostat is loose pls fix , or have a problem in PCB Board on thermostat, pls go to the nearest repairman to repair that.
Thank you,have a nice day
Edgz
Jan 22, 2008 | ACE -Air 18,000BTU Heat Pump A/C Free DVD...
Dishwasher time E4
e4 for most products means it must be reaplaced contacted the company they should be able provide a replacment
Oct 15, 2007 | Kenmore 46123 Stainless Steel Electric...
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
