Question about Asrock P4i65GV Motherboard
The error code is " 0 " with PC Analyzer PI0049F
I try to run the PC which is used the P4i65GV motherboard. But there is no beep, no display just runngin CPU Fan. So I'd test that board with PC Analyzer PI0049F, There has only show the error code " 0 ". I'd test the CPU, Memory, also CMOS battery.All of them are OK.There has no Display Card at the PC.So I'd decide that the board is gone.Can anyone give me how can I do more? Thanks
F 32
Posted on May 25, 2009
    Genius:
  • 2,985 Answers
I think this model needs extra 12v in a 4 pin connector to run the processor. The CPU will need to be cabled for it or an abaptor can be had. Check your manual
Posted on May 17, 2007
Intel d845gvad2,Motherboard getting on green light is coming but without ram board does not giving any beeps and processor fan and smps fan are running but does not giving any display,then which one may be...
you can try taking out CMOS battery from the board and try to reset BIOS jumper on the board. once you can also try removing and reconnecting the CPU Fan and CPU from the board.
All the best
Jun 08, 2011 | Intel Desktop Board D845GVAD2 Motherboard
Cpu fan is running but no display & monitor is black.
It't failed to POST, or pass the Power On Self Test.
Here are some guides that will help you repair your computer system:
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
You may find you need ot replace the mainboard.
Take care!
damnor01
Apr 22, 2011 | Asrock P4i65GV Motherboard
No video from motherboard even with new video card
Dear sir,
if this board has AGP slot, try to use AGP card inspite of PCI display card .. second thing when u power up the board . short its crystal oscillator for 2 second during switching on ..by screw drivers..if if it will not provide display .
then open fan & reinstall CPU .. if cpu is OK ( only can be tested on other board ) ..then something is wrong with Northbridge ../ or power supply mosfet of board if fan is not running ..
Regards
raj
Jan 26, 2011 | Asrock P4i65G Motherboard
No video with or without a new video card on an asrock p4i65gv motherboard
So you can no onboard video when using the onboard connection right? and no video using an external video card also right? In this case, the promblem lay with the motherboard/ram/cpu and not with your video card. Try resetting the bios via taking out your cmos battery or shorting the cmos pin to see if a miracle would happen and the system would post. If not and if you have another board with compatible hardware, then you can try testing out the cpu, the rams. If you hear beeps when starting up the system, try to take note of it and look up on the internet via what bios make it is, and decode the beep error for what is wrong. If you don't her any beep, the other way only to know what is wrong is having another compatible board to test your cpu/ram, or make sure the ram and cpu you are using is supported by the asrock motherboard. If you do have another board to test your cpu/ram and even the video card, and they work, then your motherboard is scrap and needs to be replaced.
Power on but no display processor fan running power switch light off
Power light possible means nothing, maybe a burned out led.
No display: Try feeling the cpu heatsink to see if its getting warm. If it is cold after 15 minutes running, the CPU may have failed. If warm, move onto the graphics. If using onboard, try using an aGP card and see if you get a display then.
(I'm assuming that you get a beep on powering up? If you get no beeps at all, confirms CPU is at fault, if 8 beeps on start up, probably graphics. any other beep codes, post them and I (or somebody else will help)
Dec 28, 2010 | PC Chips : PC-Chips M909G P4 /FSB...
Not booting but RAM,processor,SMPS ,HD are fine.
Check without Video Card, Processor , Memory and beeps are coming
If no then this is motherboar issue, I had the similar problem. So went to the local repair shop and got the power capacitors replaced,
Jan 29, 2009 | Asrock P4i65GV Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
CPU OR Motherboard
its your motherboard problem if its have a warranty then send it to the asrock service centre if not then repair it
Sep 27, 2008 | Asrock 775VM800 Motherboard
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Asrock P4i65GV Motherboard Logo
974 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
pankaj rautela
pankaj rautela
Alun Cox
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
