Question about Keurig Coffee Makers & Espresso Machines
The tube does not seem to be working well - Keurig Coffee Makers & Espresso Machines
  • 1,511 Answers
It is not working well...fix it.
Posted on Jan 31, 2014
A bolt has worked loose from the rocker cover, the top right bolt. a local dealer said it was an m6 x 45 flange bolt, but it seems to be a thicker bolt needs to be used? also,there is a black tube with a...
you can take that bolt to any hardware store and they can match it for a 1/10 of the price, the tube could be the over flow tube from the tank, or a tube attached to the carb,
Jul 20, 2011 | 2011 Sym Fiddle II 125
I have a Peavey ValveKing 112. It seems like it just takes forever for the tubes to warm up. For like the first hour that it's turned on the clean channel seems fine, but the second channel doesn't work....
Buy ONE new 12AX7 and try it in location V1 and if it doesn't help, try it in V2. This tube has TWO heaters in it and if one is intermittent that could cause your problem. The vibration MIGHT be "fixing" a briken heater after some time.
There are MANY components that could cause this, so you might have to take it in for repair if it isn't a simple tube problem. Since it works on the clean channel, V3 should be OK.
Feb 11, 2011 | Peavey Valveking 112 - Tube Guitar...
My extension tubes were put in incorrectly and I can;t unstick them. Suction is not great think something is stuck in tube.
Hello There! I had the same exact problem. Seems something was wrong or stuck in the tubes.
Finally, when I kept trying to clean it out, the tube ripped off and I found a clog of dust in it. So, try getting replacement tubes & it'll work for sure!
I wish I helped you! Let me know if you need anymore help! Don't forget to rate! :)
Jan 14, 2011 | Kenmore 25614 / 25615 Progressive Bagged...
Philips model # 50pp920217 I can't seem to get the colors on the tv to work properly. I have tried everything possible but the colors just dont seem right, there is not brightness to them and they are...
Sounds like the blue might be going bad. I would get a authorized servicer to come and confirm that. If it is the tube, then there is alot of work needed to replace the tube. IE. Replacing the coolant, convergence, etc.
That reminds me. Check the coolant in the tubes and make sure they aren't cloudy.
Apr 06, 2010 | Philips 60P8341 60" Rear Projection...
Black light on computer after installing xp over vista
Yes there is a tiny fluorescent tube which lights up the LCD screen. They are often difficult to find. Also while it might be the tube that has gone, there are other possibilities as well e.g. the power supply to the tube may be the problem rather than the tube itself.
Jul 25, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
Everything seems to run fine, just hasn't pulled a drop of water
remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
Jul 22, 2009 | LG LHD65EBL Dehumidifier
Water dispenser does not work on kenmore side by side refrigerato
remover the water tube from the lower section of the freezer door at bottom you will see this tube and a tubing connector,push and release the tube the line should drain out from the freezer door if not its most likely its frozen,use a hair dryer on the freezer door to defrost line and then reconnect line.
also adjust the freezer setting ti 3 no lower or higher..
nbcrca:)
Apr 11, 2009 | Kenmore Refrigerators
Frothing tube
Sheryl,
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Adam
Aug 26, 2007 | Mr. Coffee ECM10
Picture tube doesn't seem to stay in place (standard tv)
A very good chance this tv was dropped or bumped. Sounds like the internal plastic frame is broken and will not support the picture tube. Find someone with tv experience to fix this. I would suggest they use a putty found at an auto parts store. To glue the tube and the frame together. This putty is in a plastic tube. You tear off a piece and fold it several times to activate. It will surely do the job.
May 30, 2007 | Durabrand DWT2405 24" TV
Coffee Makers & Espresso Machines Logo
12 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
