Question about Samsung SCX 4521F All-In-One Laser Printer
Paper Jams I am having an ongoing problem with my fax machine. It is constantly getting a paper jam. It is making the paper look like an accordian or fan. The paper always is getting hung up on the left side (If you are looking at it from the fron) of the machine. Any ideas. Thank you
    Genius:
  • 2,985 Answers
Take out the paper tray- and examine- the paper pickup on the jamming side. Do the same internally looking at the paper feed track. If you can get a vacuum nozzle and have a good suck out. It is all most certainly paper debris in the feed . Also take a look at www.fixyourownprinter .com
Posted on May 19, 2007
Why is my fax machine jamming all the time
Dear
If paper jam always,check the thermal ribbon correctly installed (the ink coating face upward and should above the print head)
If document jam always, check the ADF roller (white roller clean it)
Thanks.
Feb 26, 2015 | Panasonic KX FP215 - Fax / copier - B/W -...
Paper jams in back of machine?
you have an obstruction either a piece of paper between the rolllers or the secondary feed rollers are not turning.... open the machine and follow the feed path ...take a piece of paper and manually feed the paper with the machine in the off position look at the feed rollers then the secondary rollers( usually two small rods with rubber sleeves kissing each other ...if you can look at the sides on the machine( inside the cover) see if the gears ( usually white ) can turn or mesh correctly... if you do not see any obstruction then these rollers are not turning when they are supposed to when you press the print button. 90 percent of these problems are paper jams if no jam something is not activating the feed rollers
Sep 05, 2014 | Brother IntelliFax-2820 Laser Fax
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
Paper jams as its feeding from the tray into the machine
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jan 27, 2010 | Panasonic Panafax UF-885 Plain Paper Laser...
Constantly getting paper jams
where the paper comes out there is a rubber roller that roller must be cleaned to get to that roller open the back cover then you will see the fuser cover that cover just drops down then you will see a white plastic remove that plastic by removing two screws at each side of the white plastic you do not have to open the rear part completely that white plastic sould come out if you wiggle it a bit you will have to take it out one side at a time then when that white plastic is removed you will see the rubber roller just clean that roller with benzine or alcohol. The machine gives you paperjams because that roller gets sticky over time.
Oct 29, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Sharp AL1642 CS Copier Grinding noise and Paper Jams
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Nov 19, 2008 | Sharp AL-1642CS Copier
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
DCP-7020
My suggestion is to take the printer to the highest floor in your building open a window and see if it can fly. or just use it as a $200 paper weight because after 3 months it has been to the shop 3 times and still is not working they way it should. Bad equipment bad support, and just plain bad product all around.
Mar 04, 2008 | Brother DCP-7020 All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
177 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
