Question about Dryers
My dryer is not heating at all. I removed the front panel to check the ignitor but I am not sure where that is?
  • tagama2 Jan 09, 2009
    Thank you for your help! I was able to fix the dryer and it was easier than I thought. You were very helpful.
    Thank you
    God bless you
    Tonya
  • Sheldon Scott
    Sheldon Scott May 11, 2010
    Could you please tell us the make and model of your dryer?
    Sergeant:
  • 311 Answers
Your ignitor is in the burn tube attached to the burner.it has two wires coming off it.if when you start your dryer you then hear two clicks and ignitor not glowing the check voltage at ignitor.if only one click its the thermol fuse.you can put the thermoal fuse wires together to test if its bad.God bless ,tom
Posted on Jan 04, 2009
Dryer turns on and acts normal, but does not get hot. Product is barely 1 year old.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 18, 2010 | Samsung DV219AE Dryer
No heat,vent clear if i remove toe panel can i see ignitor how do i remove toe panel?
check thermal fuse in back near exhaust. or on top of burner tube. if your dryer has a toe panel there are 2 clips on either side at the top that you can release with a putty knife. if no panel you have to take off the whole front. If ignitor glows and no ignition replace the valve coils.
Jun 15, 2010 | Kenmore 75962 Gas Dryer
No heating?
If the unit runs and heats for a short time, then only runs without heating, it may have bad gas coils(2 solenoids that are screwed on to top of gas valve)
If the unit runs without any heating would check the ignitor or the thermal fuse.(ignitor is fragile)
Check it is not accidentally set in air fluff....
Most all whirlpool dryers are front serviceable by lifting the top(two screws by air filter and putty knife pushing in about two inches on each side in front) Some have a lower front panel, most you remove the front to access parts. Sharp edges and unplug while servicing. The ignitor and thermal fuses can be ohmed out at a service store. There are other possibilities, these are the most common, good luck.
Apr 19, 2010 | Whirlpool GGQ8831L Gas Dryer
Can't access the ignitor on my dryer.
Here is a video that will help you out click on sample video toward the bottom of the page..
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/Whirlpool-gas-dryer-not-heating.html
Sep 13, 2009 | Dryers
Dryer not blowing hot air
Hi, If you use the automatic dry cycle, there needs to be heat in order for the timer to advance.
Remove the little cap in the front lower left corner and start the dryer. The ignitor should glow for about 15 seconds and then the gas should ignite. If there is no glow from the ignitor and the fuse is good, you will need to remove the front panel and check the senser on the burner, the ignitor, and the thermostats.
I hope this helps you. If you need more assistance on this issue, please let me know.
Vic
Jul 03, 2009 | Kenmore 63942 Dryer
Accessing the igniter on a Kitchenaid Dryer
Normal 0 Hi, UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the ignitor attached to the burner. There is a harness you can unplug to test it. If the dryer is not heating at all, before you remove the front panel, you can remove the cap on the front lower panel and start the dryer. Look inside the holw and see if the ignitor glows at all.
If it glows and then shut down before the flame lights, you will need to change the coils on top the gas valve, not the ignitor.
If the ignitor does not glow at all, you will want to test the thermo fuse before the ignitor.
Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. I know this is a lot of info but these are most common problems.
If I can assist you further, please let me know.
Vic
Jun 02, 2009 | KitchenAid KGYS850LT Gas Dryer
Gas dryer runs but no heat
Hi, Remove the little cap on the front panel lower left corner and start the dryer. Look into the hole and see if the ignitor glows (5 - 10 seconds)
If the ignitor does not glow, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If the ignitor glows and then shuts off before you see a flame, try this:
Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto. I know this is a lot of info but, it's the most popular problems.
Please let me know if this help or if I can assist you further.
Vic
Jun 01, 2009 | Dryers
Dryer heat turns off after about 5 min- dyer will remain running but no heat
HI, After the heat shuts down, do you hear a click like it is trying to heat again but then get no flame. The most some problem is the coils on the gas valve go bad and will not reopen after they have heated up.
Remove the cap on the front lower left panel. After dryer has ran and heat shuts down, watch and se if the ignitor glows again (you will hear a click) and the ignitor shuts off before a flame. If this happens, change the coils on th gas valve.
Here is instruction: Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
Thanks
Vic
Dryer won't heat up
HI, Can you see the ignitor glow at all? If not, check the thermofuse first. It is located on the blower housing white, /4" wide, & 3" long. If you can remove the rear panel on your model, that is where the fuse is located. If you can not remove the back panel, some models you have to remove the whole front panel and some the lower half front panel comes off.
If the ignitor does glow, you will need to replace the coils on top of the gas valve.
I hope this helps. Please let me know if I can assist you further.
Vic
May 19, 2009 | Dryers
Dryer runs but will not heat-vent and exhaust hoses appear clear.
Disconnect power from the dryer. Open the door and remove the 4 phillip screws from the inside lip of the door opening. Lift the door slightly and remove by sliding the hinge out from the slot on the cabinet. Grasp the front panel near the upper holes of the screw just removed. Twist from the inside out and pull away from the cabinet at the same time. Lift the front panel off of the bottom clips to gain access to the igniter. DO NOT touch the new ignitor surface as it is extremely fragile. The ignitor is attached by a single screw. Make sure the molex connector to new ignitor is secure.
Reverse the above procedure to reassemble.
Apr 25, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
101 people viewed this question
Top Dryers Experts
