Question about Air Purifiers
How to Auto Clean Aquaguard Total Infinity Water Purifier?
What is the best way to clean your air purifier that has cigarette smoke
Try vinegar and water solution. Some people prefer Javex with water for tougher stains but be careful to air it out before exposing anyone to the fumes. Read the instructions for the ratio of Javex to water. Good luck
Dec 07, 2013 | Honeywell Enviracaire Elite F300E-1019 Air...
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
Red light blinking with beep in aquaguard classic
Do Press water start button on_off, for 2time and keep that in off conditions. Now start the machine.
Nov 08, 2011 | Ecoquest Living Air Classic Air Purifier
How often shoule you clean/change the plate? how do you clean it?
You should clean the purification plate once a month. Using a 1 part water and 1 part amonia solution, dip an old toothbrush into the solution and scrub the metal grids on the plate to remove any dirt or deposits on the grids. Remember to do both sides of the plate. After the grids have been scrubbed, rinse with warm tap water and allow it to dry completely or use a hair dryer to speed up the drying time.
It would be a good idea to scrub the metal contacts that touch the plates inside the purifier as well. The plates should be changed if they develop a crack or there is noticeable arcing when the purifier is running. Hope this helps you.
Dec 09, 2010 | Alpine Air XL-15 Air Purifier
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
How do I clean my EcoQuest Breeze?
The purifier should be cleaned about once a month and you should do the following:
  1. Unplug the Breeze before cleaning.
  2. Wipe the Breeze with a soft cloth dampened with water, vacuum the front grill to remove any lint buildup.
  3. Cleaning the rear lint screen - You can either vacuum the filter or you can wash in hot water. Allow to dry before reinstalling the lint screen. Do not use soap, it will damage the carbon material in the lint screen.
  4. Remove the purifier plate from the purifier and soak in 1 part amonia and 1 part water solution for 10-20 minutes. Gently scrub the metal grid on the plate with a toothbrush and rinse with water. Clean the metal contacts with the same solution. Allow the plate to dry overnight or use a hair dryer to dry throughly.
Dec 07, 2009 | Ecoquest Breeze AT Living Air Purifier
Metal screen cleaning? pads required?
Soap and water will work just fine. Rinse thoroughly with hot water. I'd dry it with a hair dryer before reinstalling it.
"Should I use the pads?" -- Could you please clarify this question.
thanks...
Charlie
May 29, 2009 | Ecoquest Flair Air Purifier
No smell
clean plates and blow out guts with compressed air. clean plates with mix of water and amonia!
Sep 28, 2008 | Ecoquest Flair Air Purifier
Air Purifiers Logo
344 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
