Question about Xerox Phaser 6250 Laser Printer
Xerox phaser 6250 engine fuser warm up
Printer will not start up...keeps getting stuck at engine fuser warm up
  • 186 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
time to replace the fuser assembly.
Posted on Jun 21, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
  • 191 Answers
SOURCE: i own a Xerox Phaser 3100MFP and it keeps giving
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Posted on Sep 22, 2009
SOURCE: My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Posted on Jan 06, 2010
How do I find the page count for the printer
Phaser 6250 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-6250/support/enus.html
XeroxProduct support for Phaser 6250. ... with our support knowledge base directly, and troubleshoot itself. Automated Remote Diagnostic Tool - PhaserSMARTâ„¢ ...
Oct 02, 2015 | Xerox Phaser 6250DP Laser Printer
Xerox phaser not completing warm up
Try resetting. Power unplug - not off only for a few minutes and replug. You might get lucky.
Dec 08, 2013 | Xerox Phaser 6250 Laser Printer
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
Xerox 6250 will not warm up. it says
Yes it can be the used fuser. Kind of odd for it to be anything else but the fuser.
Jan 25, 2010 | Xerox Phaser 6250 Laser Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Xerox phaser 6250
There are two release latches on the Phaser 6250: A and B. If you open the front using the A latch on the front of the printer you will not see what you need! If you open the B latch on the right side of the printer you will see the orange locking sliders in your diagram #4. Move these to the unlocked position and then open up latch C. This is an orange lever inside the printer on the left, behind the fuser assembly. Once you open this you can remove the fuser.
Oct 07, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Nov 19, 2007 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 6250 fuser issue
I was stressing out to change the fuser. But, your directions were as simple as A-B-C. Thanks a lot!!!! It worked
Sep 02, 2007 | Xerox Phaser 6250DP Laser Printer
Open Questions:
Xerox Phaser  6250 Laser Printer Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
