Question about Microsoft Office Mac 2004
Auto caps in Word
Hi
I don't want a CAP at the start of each line. How do I turn that "feature" off?
    Scholar:
  • 35 Answers
To turn off automatic capitalization and text corrections:
  1. On the 'Tools' menu, click 'AutoCorrect'
  2. Click the 'AutoCorrect' tab, and then clear the check boxes for the options that you want to turn off.
Posted on Jan 04, 2009
  • Leon Ardelean
    Leon Ardelean Sep 17, 2013
    Thank you. How simple that was!
My fpd1975w gateway monitor turns on but shows only red, green, blue line across the screen the shuts off
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Jul 11, 2011 | Gateway FPD2185W 21 in. LCD Television
Power button on TV does not work. Power button on remote still turns on cable box but not TV
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, I would concentrate on the power supply section.
Any caps in these or any sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
The parts are cheap, and skill required is minimal. There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
As you can see, this issue spans plasma TVs, as well as large and small LCD and projection TVs and monitors.
Jul 01, 2011 | Televison & Video
Hi i have got a emerson hdtv lc195em9, it worked for over a year ,and one day just stopped working, the screen just turned of by itself and the power green button flashes on and of, i plug it right now to...
This issue is becoming more and more common across a broad number of manufacturers and products.
Jul 01, 2011 | Emerson LC195EM9 19 in. LCD TV
Monitor wont turn off
Jun 17, 2011 | ViewSonic VX2245WM LCD Monitor
Hi, my 01 Bonneville SSEI keeps saying check gas cap, then the check engine light comes on, I have replaced the gas cap and that did'nt fix it. Any suggestions? Thanks.
Hello: You need to find out if there are any codes in the engine control module. Go to a parts store ie: Auto Zone, Advance Auto and have the codes read, they normally don' charge. If the code is for the Evap system have them clear the code and see if it comes back.
Jun 16, 2011 | 2001 Pontiac Bonneville
When you turn the tv on it the picture flickers and freaks out and does not stop! Please Help
The solution I am about to provide normally is for units that don't turn on, but if your power supply is failing, the solution still applies to you!
There's a good chance you have failing electrolytic capacitors in the power section.
Any caps in any sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on properly, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
May 30, 2011 | Hitachi Televison & Video
How do you add refrigerant.
If you follow the lines coming from the A/c compressor, you will find a red cap on one line and a blue cap on the other line. The blue cap is the suction side. Remove the blue cap. You can buy recharge kits at the parts store that have a line and tap included. You just couple the line there, open the valve on the freon can and start the engine. Run the a/c on high. Be careful not to overcharge the system. If the belts start squeeling, that will indicate too much freon in the system and a high presure situation.
May 12, 2011 | 1999 Buick Century
Where do i find the ac charge port on my 2003 trailblazer
you can get help at a auto parts store, auto zone , advanced auto etc etc. they have a lot of free services. they also have do it yourself repair manuels , haynes ,chilton . if your going to keep the vehicle make the small invest ment . you can also check half priced book stores. yes i know this is not a direct answer to your question you need to know witch is the hi line and which is the low line. some times they have a cap over the conection that has h or l for example thats if some one didnt put the wrong cap on the wrong connection.
Aug 03, 2010 | 2004 Chevrolet TrailBlazer
Trying to flush radiator, where is plug in block, or can I just take bottom hose off radiator, to drain all coolant.
go to auto zone/ O"rileys and buy a flush kit, it is a kit that allows you to cut, a heater hose and install a TEE with a cap on it, the cap end is also the hookup for a water hose, wait until the engine is cool, cut the hose install TEE, hook up water hose, remove radiator cap, turn water on low, crank engine and flush until water is clear, reinstall cap and your block,radiator is flushed, don"t forget to put in coolant
Sep 25, 2009 | 2006 Ford F-150
Microsoft Office Mac 2004 Logo
299 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
