Question about Kenmore 46462 Front Load Washer
Flashes F-21 when I try to start a load - Kenmore 46462 Front Load Washer
  • erica graber May 11, 2010
    Is there water entering the unit?
  • 5,911 Answers
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
I hope this helps you. Let me know if you require additional assistance.
Posted on Jan 04, 2009
Fi code flashs 3 times...won't start
The three flashes indicate a fault code,are they three long or short flashes? A long flash is a ten and short is a one,so for instance if you have one long flash and two short ones that is fault code 12 if it was three short flashes that would be 3 ect... You will have to Google the fault code numbers to see what they mean ,ie fault code 21 could be oxygen sensor fault.
Sep 17, 2017 | Motorcycles
I have a Whirlpool front loading washing machine and when I try to do a load of laundry, it will wash, but then flashes an F21 error message....and stops......I have tried canceling the load and restarting...
The F-21 code is a blocked drain tube. Take off the front lower panel and locate the drain. Should be front right, Disconnect it and clean out the little trap that collects stuff. Put back together and should be fine. I always find stuff like coins and tissues wadded in there. It made for collecting foreign matter to keep the drain clear.
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Start a normal load then it stops and flashes f 21
Possible Causes / Procedure
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. after 10 minutes plug in and retry.
4. if this does not work you need service.
Apr 27, 2010 | Maytag EPIC MFW9700S Front Load Washer
Hi my zanussi zwf1432s stopped halfway through washing green light on start/pause button flashs wont do nothing else all lights will change when cyle chosen but will not start justs beeps then back to...
Hello Paula,
Do not know how many flashes but 1green/1red = 11 water pressure low.
2green/1red = 21 blocked filter or pump fault.
You would be best firstly checking the filter and make sure it is clean and pump turns.with water drained and filter out shine torch into filter put on spin/drain and see if pump blade spins if not then try and turn with long screwdriver to free out any debris then refit filter and check for leaks and try donnt fill fully until you are happy it can drain water.
Hope I was of some help.
Good Luck
Apr 22, 2010 | Zanussi ZWF1430W Front Load Washer
Load stops and flashes F-21
F-21 is a code that indicates "long drain".Check the drain line for kinks or obstructions. Check the pump. Check eletrical connections at the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F 21? washer stops
Hi
The error code F21 means LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES: After 4 minutes the “Sd” error will be displayed, and then 4 minutes later the “F/21” error code will be displayed. Press PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
PC101E - Dew Sensor flashes up when I switch on the camera
rub the dew sensor with q-tip & alcohol and the condensation warning should disappear!
Mar 18, 2009 | Sony Handycam DCR-PC101E Mini DV Digital...
My Washer flashes F 21
Your filter is probably clogged. Unplug the washer and remove the lower front panel (three hex screws). You may need to tip the washer back to do this - be sure to have someone hold the washer while you work. The filter is about 3 inches in diameter and unscrews from an assembly just to the left of the pump, which is on the right side of the washer. It is hard to turn, but with a little muscle it will unscrew. Be prepared for water to gush out. It can be a lot or a little depending on how much water is left in the tub. Once unscrewed, clean out all the junk that has accumulated in it. Make sure the the pump rotated freely and doesn't have any obstructions. Then screw the filter back in and put the panel back on. Assuming you found a lot of junk inthe filter, this should solve your problem. Good luck.
Mar 18, 2009 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Robert Rankin
