Question about Norelco Health & Beauty
Replace batterys emerson shaver
Replace batteries
geokohler
  • 304 Answers
SOURCE: battery replacement
I have the .PDF file from remington for disassembling your shaver for you. Also this model is known for poor battery life and I recommend replacing the NiCd batteries with Lithium Ion batteries of the same size. This will give you much more shave time and 10 time the number of recharge cycles. Post me an E-mail address where you want me to sent the instructions to you or you can just E-mail me and request the instructions and I will attach the .PDF to my reply letter ( geokohler@gmail.com). If you enclose your number I will call you for free and walk you through the process.
I hope you find this information valuable. If you do please take the time to rate this a FixYa. If you ever need my help again post it here and I will be notified of your need for further assistance by E-mail. I do this for a hobby so there will never be a charge.
Sincerely
George
Posted on Jul 28, 2008
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Posted on Mar 21, 2009
Cytherian
  • 109 Answers
SOURCE: My shaver won't hold a charge.
Yes, you can replace just the batteries. It's fairly common that the motor will last far longer than the batteries, so you can purchase them separately and install them. You can usually find them at about $12 a piece on "that auction site." Here are the instructions:
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Posted on May 23, 2009
How to Reset Battery Braun 8585
You will find videos for dismantling the shaver as well as replacing the batteries at shaveroutlet.com. See link below for correct replacement battery type and videos
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-replacement-battery-aa-nimh-p-108.html
Mar 23, 2013 | Braun 8585 Electric Shaver
Battery replacement for norelco 5822 SL shaver
You will find batteries for model 5822XL at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Nov 08, 2011 | Norelco Reflex 5822 XL Electric Shaver
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
What is the replacement battery for R9100 razor and how is it fitted
You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jan 16, 2011 | Remington MicroFlex R856 Electric Shaver
Health & Beauty Logo
23 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Andrew Taylor
Andrew Taylor
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
